Chris7
posted on 27/6/03 at 03:45 PM |
locost 7
Hi i am building a locost 7 which i bought as a part built kit i think it has a cortina back axle not sure anybody any ideas how i can tell what it is
escort / cortina . once i find the model i would like to recon it but not sure where to get bearing and seals from .
Any ideas would be appreiciated
chrisg
| posted on 27/6/03 at 05:09 PM |
Not sure of the widths, although it has been discussed before on here.
The Escort axle has an external lever to operate the handbrake whereas the Cortina handbrake cable goes into the back plate.
Someone will have the widths tho, or you may find it in a search.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Chris7
posted on 29/6/03 at 07:58 PM |
problem resolved
Hi Thanks for that
craig1410
| posted on 29/6/03 at 09:58 PM |
Been discussed in more detail recently. Use www.carfolio.com to find technical specs including track wisth of cars.
The escort and Cortina should be easy to identify since the Cortina is 56" track width and the escort is 52". Note that track wodth is
width between the centre of the tyre tread so you will need to compensate to get backplate width.
HTH,
Craig.
