New Topic New Reply
Author: Subject: Polo Rad fixing screws
Tinks
posted on 30/1/07 at 04:47 PM Reply With Quote
I have tried looking for other threads but not found any on this..... Can someone advise me of the screw type and size that is used to fasten the bracket to the Polo VW302 radiator.... is it a plastic selt tapper...?
Thanks in advance
John
pewe
posted on 30/1/07 at 05:15 PM Reply With Quote
Tinks, I used ordinary zinc plated self-tappers but make sure they are blind ended or cut the points off - just to make sure they don't go too far!
Cheers, Pewe
flak monkey
posted on 30/1/07 at 05:17 PM Reply With Quote
I tapped the holes M6 as they are a 5mm hole anyway. Fine if not done up too tight.
Sera
http://www.motosera.com
Marlon
posted on 30/1/07 at 05:21 PM Reply With Quote
as above without the tap, I just wound in m6 bolts, It went in quite easy.
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
rayward
posted on 30/1/07 at 05:27 PM Reply With Quote
tapped M6 and screwed M6 studs in with threadlock
on
Ray
Surrey Dave
posted on 30/1/07 at 06:20 PM Reply With Quote
Length?
Tapped holes to 6mm and cut bolts to suit , if they are too long they will bottom out and probably break through.
the_fbi
posted on 30/1/07 at 07:50 PM Reply With Quote
There is a Merc A class airfilter mount which is a double ended M6 with an antivibration rubber bonded between. (basically an antivibration mout) this is what I've used. Works a treat.
Studs are the right length and you get anti-vib mounts too
Part number is on here somewhere.....
Edit:
4 x A116 988 05 11 @ £ 1.73 each + VAT.
[Edited on 30/1/07 by the_fbi]
RichardK
posted on 30/1/07 at 08:08 PM Reply With Quote
As above tapped to M6 and short M6 bolts used.
Rich
Gallery updated 11/01/2011
Danozeman
posted on 30/1/07 at 08:13 PM Reply With Quote
M6 in mine...
Dan
Simon
posted on 30/1/07 at 08:22 PM Reply With Quote
Used 1/4" whitworth on mine - all I had lying around
Simon
omega 24 v6
posted on 30/1/07 at 08:34 PM Reply With Quote
M6 for me too.
SixedUp
posted on 30/1/07 at 09:19 PM Reply With Quote
I had nothing the right size, so I ordered a set of the official self-tappers from VW. They had a full set for me the next morning, total cost was something like £1.80 ...
Richard
westcost1
posted on 31/1/07 at 12:13 PM Reply With Quote
my rad came with the self tapers in it!
Tinks
posted on 31/1/07 at 12:34 PM Reply With Quote
Thanks Guys' M6 it is !!!!
New Topic New Reply
