slopecombat
posted on 3/2/07 at 01:57 AM |
"bending" tube ...
25x25x2mm
Easy !
Modesto
panichat
posted on 3/2/07 at 01:14 PM |
Could I ....?
Is there a good reason why I couldn't do something similar with the upper round section tube? - I think I could make it much neater than with my
useless bending. If the roll bar supports go to the lower rear corners instead of the upper bar there wouldn't be any chassis strength issues to
worry about would there?
Dave
James
posted on 3/2/07 at 04:03 PM |
I did something similar to get the bend in one of my exhaust tubes.
Except I did about 30 cuts and to keep them narrow enough... by hacksaw!
James
- Muhammad Ali
andyps
posted on 3/2/07 at 05:24 PM |
The only problem I can see with doing it this way is getting the panel neat on the square section - without any experience I would imagine it would be
much harder to make it look neat on square section than round (assuming you are using ali rather than grp).
DIY Si
posted on 3/2/07 at 06:23 PM |
There's no problem strength wise doing it, as Indy's don't even have a top tube at all! As said, it may cause a slight issue getting
the bottom of the back panel to sit right, but only if you're using ally.
Sun Tzu, The Art of War
kb58
posted on 3/2/07 at 07:36 PM |
I used that method for "bending" my dash tube. What happens is the shrinkage from the multiple welds can result in a very differnent shape
than what you started with!
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
slopecombat
posted on 4/2/07 at 12:24 AM |
Upper corner in progress ...
![](http://perso.wanadoo.es/msm-software/assets/images/Tubo7.JPG)
kb58
posted on 4/2/07 at 02:10 AM |
You left out the most important step... welding it. When you weld it, that 90 degree shape will absolutely change, even if you alternate sides.
It can work, but don't expect it to stay at its initial angle! After welding all the cuts, you'll have to add another cut to put the angle
back where it started.
And its book -
Dick Bear
posted on 4/2/07 at 04:51 AM |
You should have no movement or distortion if you spot-tack all cuts first and as you bead weld skip around (top, back, one end then the other etc.)
never letting any one area get too hot. Short beads and move around the entire part.
On a small piece you may also want to clamp it to another straight channel until you get the spot tacks in place. It is important to weld straight on
through the tacks as if they don't exist.
Dick Bear
www.marketpointproductions.com
gottabedone
posted on 4/2/07 at 09:54 AM |
If you make a template/former for the outside of the curve (3/4 MDF or ply) and clamp from top to bottom, you could then spot the joins on the inside
of the curve, adjust where necessary, spot the top, adjust again before it is too rigid. You should be able to minimise the distortion and keep your
finished curves the same. Be careful when you attach you panels to these curves because if there are large gaps between the back of the panel and box
section it will create stress raising areas and my eventually crack the panel or pop your rivets.
regards
slopecombat
posted on 4/2/07 at 05:16 PM |
Welded ...
I'll take pictures of the hole process in the last corner.
Modesto
panichat
posted on 4/2/07 at 06:43 PM |
Looks good
OK, I'm inspired!
This is my next job on the car so here goes...
Dave
slopecombat
posted on 11/2/07 at 03:09 PM |
Pictures of the process
Here you are :
cheers,
Modesto
John Bonnett
posted on 11/2/07 at 04:18 PM |
This has been mentioned before but just to repeat, square tube (as well as round tube) can be bent very nicely cold using a bending beam.
John Bonnett
posted on 11/2/07 at 04:21 PM |
Sorry forgot the pic
