bpgoa
posted on 7/2/07 at 11:32 PM |
loan of an M18x 1.5 tap
feel really cheeky, but would anyone loan me a m18x1.5 tap? ... I'd pay for the return postage or I'm based in Hertford if anyone lives
close.
I'd like to make some wishbones this weeekend but don't own a tap... and their kind of expensive for just two holes.
Adrian
On and On the River flows... We the Undertow
welderman
posted on 8/2/07 at 08:24 AM |
will see what we have in our tool room,shhh.
first ?
second ?
third ?
[Edited on 8/2/07 by welderman]
Thank's, Joe
I don't stalk people
bpgoa
posted on 8/2/07 at 11:42 AM |
Thanks....
I'll tap them in the lathe(turning slowly by hand).. so i'd probably get away with just a second ... and run it through... if you have a
third as well though
i'll u2u my address... send me yours for the return....
and big thanks(said quietly)...
P.S. it's for the transit ball joints ... M18x1.5 is M18 fine?
posted on 8/2/07 at 11:54 AM |
A hint - don't fully-form your threads then weld up the wishbone, as threads make get spoiled and the hole distorted (guess how I found out...).
If nothing else, the threads get covered in oxide that should really be cleaned off.
If I was doing it again, I'd make a few turns until the taper tap was fully engaged and thus lined up straight, weld up the wishbone (taking out
the tap first!) then finish the tapping at the bench.
Just my 2p's worth...
bpgoa
posted on 8/2/07 at 12:04 PM |
Hints are good
Thanks...
I'd much rather learn from other people mistakes than my own...
(why do kids not do this!)
welderman
posted on 8/2/07 at 07:02 PM |
in the post, its spanking new too, second taper.
Glad to help.
Thank's, Joe
posted on 9/2/07 at 11:42 AM |
any use?
Ext
ended M18x1.5 Threaded Tubes For Locost Wishbones
bpgoa
posted on 9/2/07 at 11:00 PM |
Received- one tap
Thank you welderman....
will weld up and return early next week...
...02f.. I want to try and make as much as i can myself... and see davids post in this thread... thanks though....
