robertst
| posted on 6/3/07 at 01:19 AM |
triangular plates
got a week to work on the car and i fitted the triangular plates under the roll-bar bounts. wanted to know your opinion.
As you can see, i had made an error in the position of the diagonal tube, but i made these plates out of 3mm plate and welded them in.
should that do? i think it actually might have more strenght as it goes around the box section rather than on top...
Tom
| posted on 6/3/07 at 01:34 AM |
It may well be stronger like that, but I have to wonder where your rear suspension brackets are going to fit?
Mr Whippy
| posted on 6/3/07 at 01:38 AM |
so long as you can still get the bracket for the coilover in it does look stronger though I would add a plate as in the pic below
Mr Whippy
| posted on 6/3/07 at 01:41 AM |
I wondered aswell and had to look at one of my chassis, I think there's more room than it appears in the picture.
| posted on 6/3/07 at 01:51 AM |
I reckon even if you can squeeze a bracket in, there is a good chance of the top spring seat of the shock fouling the diagonal tube.
I'm sure something could be worked out though, possibly a shorter shock and put the bracket on the bottom of the diagonal tube.
robertst
| posted on 6/3/07 at 10:54 AM |
thats another story i can do many things about the shock. as the bushes are quite narrow, theres quite some space to work on...
Tom
