New Topic New Reply
Author: Subject: comments
timf
posted on 14/7/03 at 08:36 AM Reply With Quote
comments
Having joined the ranks of the non std locost builders club (BTW what did happen to this Hippy) in using a chevy 350 in a home built chassis, plans deleloped in conjunction with Jim Mcsorley http://www.mcsorley.net/locost/
we have got some 3d renderings of the chassis.
i Know there is no bracing in place so please dont tell me its not braced
timf
timf
posted on 14/7/03 at 08:37 AM Reply With Quote
blueshift
posted on 14/7/03 at 10:43 AM Reply With Quote
Do you know somewhere to get models of engines from? we could do with a scale model of a rover v8, lt77 gearbox and sierra diff
we've been playing with CAD too
Spyderman
posted on 14/7/03 at 10:46 AM Reply With Quote
My biggest concerns with using such a beast of an engine are 1, would you be able to get the engine low enough and 2, will you have any legroom left to be able to operate the pedals?
Another problem with V8's is the amount of heat they create. Even in larger cars the transmission tunnel always gets very hot and it can get very uncomfortable in the cockpit.
I look forward to seeing it progress!
You can't beat the sound of a v8 engine!
Terry
ps, if you have two exhausts does the SVA man test both for noise?
Spyderman
timf
posted on 14/7/03 at 10:53 AM Reply With Quote
Hi terry
The engine as shown is the height installed. The legroom is not a problem as Jim sent me some rough dims and i mocked up to check for such things and made some adjustments.
The heat angle will be mostly cured with the inclusion of some form of vents on the side panel also i have some heat insulation stuff i will place stratigically around the car.
Mr sva does indeed test both exhausts on a v8 for both noise and emisions so for testing a decibel insert will be used then taken out for the glorious sound of a V8 with 420bhp
Tim
[Edited on 14/7/03 by timf]
timf
posted on 14/7/03 at 11:00 AM Reply With Quote
blueshift
the engine model was done with a tape measure and Jim plugging the numbers in so afraid can't help on that one
Tim
mackie
posted on 14/7/03 at 02:05 PM Reply With Quote
Check out our chassis. It's a Mcsorley 7+4.
We will build the tranny tunnel around the gearbox. Need to devise a mounting for the diff too. Blue - is your de dion model ready for incorporation?
[Edited on 14/7/03 by mackie] Rescued attachment chassis2.jpg
blueshift
posted on 14/7/03 at 04:53 PM Reply With Quote
It's not ready. don't have various measurements and stuff, and info about shocks.
Plus we will need to look at how to cram the v8 in there, and look at cymtriks mods list.. I think that picture may change a fair bit before the end.
looks pretty though, doesn't it?
mackie
posted on 14/7/03 at 06:09 PM Reply With Quote
Yeah, but what you see there won't change much, although we may need to tweak the front bulkhead a bit depending on how our engine fits. I don't think it will be a big problem fitting it in... i hope.
Rorty
posted on 15/7/03 at 02:44 AM Reply With Quote
timf:
OK, but shouldn't there at least be one wheel at the front?
Cheers, Rorty.
timf
posted on 15/7/03 at 07:40 AM Reply With Quote
Originally posted by Rorty
timf:
never heard of invisible wheels ?
DaveFJ
posted on 15/7/03 at 08:18 AM Reply With Quote
Yep - went to Liverpool once and in the morning my car had invisble wheels....
posted on 15/7/03 at 08:30 AM Reply With Quote
...are those the ones that cunningly disguise themselves as house bricks?
DaveFJ
posted on 15/7/03 at 09:48 AM Reply With Quote
thats the puppies - how did you know!!
stephen_gusterson
posted on 15/7/03 at 09:51 AM Reply With Quote
Wow
you got bricks! thought they were optional.
A guy I worked with once had a 10 year old lotus esprit. He left it at work on axle stands, as he was using company facilites to repair the rear universal joints.
The next day someone had left the car but stolen the stands!
atb
steve
New Topic New Reply
