New Topic New Reply
Author: Subject: how to determine chassic flex, torsion and rigidity
ChefChristian
posted on 8/3/07 at 06:22 PM Reply With Quote
I need some engineering help here guys. This is for my chassis. I am building a simple ladder frame with cross supports and triangulation.
It will be 92 inches long. I understand that bigger diameter is better than larger wall thickness.
I am trying to determine if I can use 50x50x2 or if I need to go up to a 100x50x2+.
Any math that you can run for me would be great. I can find my own answers but I need to know where to look, in what books or what websites.
Chippy
posted on 8/3/07 at 10:38 PM Reply With Quote
I may be wrong, but seem to recall. The deeper the chassis rails, 100mm as against 50mm, with X rails of the same dimention will give a chassis that will flex less. How you cross brase the frame, and attach parts, ie suspention etc. will also have an effect. HTH Ray
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 11/3/07 at 12:06 PM Reply With Quote
Chassis
Build yourself a wooden model and play. I used wood from B&Q 6mm x 6mm and a glue gun.
Torsional is important. Build and twist the model, add memebers double them up etc.
You will learn more this way than any maths, books or advise.
Basic rules are:
1) Bigger the section the better.
2) You need everyside of the box triangulated or panalled.
cymtriks
posted on 11/3/07 at 11:22 PM Reply With Quote
50 x 50 is hopelessly inadequate.
100 x 50 x 2mm wall tube made into a simple ladder with one tube down each side, a front and rear cross member and an X brace with the ends of the X reasonably close to the suspension pickups will be slightly stiffer and lighter than the book chassis.
The book chasis can easilly be improved by sorting out the triangulation. An improved spaceframe would give the best result for a seven style of car.
posted on 11/3/07 at 11:34 PM Reply With Quote
So it will likely be heavier once you add in all the structure required to support the suspension units, the bodywork, upper seat belt mounts etc? A space frame makes things a lot easier in this respect.
ChefChristian
posted on 12/3/07 at 01:37 AM Reply With Quote
I have researched the forums under cymtriks, Rorty and Syd Bridge. I am going to be starting to build the frame from wood but want to find a source for the standard deflection as wood and steel will still be substantially different. This will not be a 7esque frame. very go-cartish with almost no bodywork or suspension.
Doug68
posted on 13/3/07 at 01:00 AM Reply With Quote
When building a wooden model the idea is to determine whether one arrangement is stiffer than another.
What you're not going to get from it is a measurable stiffness thats of any real meaningful value.
Normally when design a frame people aim for as stiff as possible, but as you are referring to Karts you might be thinking of a deliberately flexing chassis?
If you Google 'wood tensile strength' for example you'll get plenty of results which vary depending upon what type of wood you are talking about.
The other route you can take is to use a stress analysis package of which there are many free ones (again Google) and take your pick until you find one you like. It's easier to go wrong with these versus a wooden model. And the results will not be the same as what you get in real life but you do get numbers to do comparisons with.
posted on 13/3/07 at 10:51 AM Reply With Quote
You need the values of the Young's Modulus (the modulus of elasticity) "E" for steel and the type of wood you are using rather than the any of the various tensile strength(s).
Mild steel has a value for E approx 207 GN/M^2
Timber(?) is quoted at only 9 GN/M^2
Calculating a "first guess " approximation of the torsional stiffness of a bare ladder frame using basic torsion theory is relatively easy, although the devil is in the detail and number and design of cross members has a major effect.
However Ladder frames are really best avoided --- just drive following an unladen long wheelbase flat bed truck on a country road if you need convinced.
If you really really want a ladder frame take a good look at a Range Rover or Land-Rover Defender chassis and jcopy the metal thicknesses, section size and cross member detailing.
Doug68
posted on 13/3/07 at 12:17 PM Reply With Quote
Quite it's Young's Modulus that the important one in this regards, don't know what I was thinking earlier.
posted on 13/3/07 at 12:31 PM Reply With Quote
Truck chassis are designed to twist though which is why they normaly use U shaped channels rather than box section and have minimal cross bracing.
My biggest argument again a ladder chassis in terms of a 7 style car is the amount of extra structure you would need on top to support the suspension and body. A space frame effectively gets you all this for nothing.
ChefChristian
posted on 14/3/07 at 02:36 PM Reply With Quote
this will not be a 7esque frame. I have included a pic of my go-cart inspired locost.
As you can see there is some frame geometry that needs to be worked out. The frame will be two rails that run from the front wheel to the rear alxe with cross members in between. Rescued attachment greenmachine2d2.jpg
New Topic New Reply
