JC
| posted on 15/3/07 at 08:27 PM |
Seatbelt threaded inserts again - sorry!
I may finally be about to sort out the top harness mounts on my midi. I intend to put them HORIZONTALLY through the 50x50 cross member behind the
seats - the height is SVA OK! I will reinforce the cross member with some 3mm plate. I had thought about having a 'flange' on the end of
the tubes, as in the lower diagram, but it occurs to me that this might not be such a good idea as it will create a stress point at the
'shoulder'. Anyone got any opinions please? Thanks JC
nitram38
| posted on 15/3/07 at 08:37 PM |
Inserts are horizontal on my car and it passed no problem. Just make sure that the are above the minimum heights as per the sva manual.
| posted on 16/3/07 at 09:36 AM |
you've shown the cross member as square - SVA manual mention that belt must not run over sharp or abrassive edges - not sure if that appplise
buty something to be aware of.
James
| posted on 16/3/07 at 10:11 AM |
If you're using 'eye' bolts with your threaded tube then make sure you orientate the tube correctly so thay 'eye' is the
right way round!
James
- Muhammad Ali
