New Topic New Reply
Author: Subject: 7/16 threaded inserts
stuart_g
posted on 23/4/07 at 09:28 PM Reply With Quote
Where can I get some 7/16 threaded inserts in stainless steel? If these can not be bought how difficult would it be to put a thread into stainless tube if I got a 7/16 tap?
posted on 23/4/07 at 09:53 PM Reply With Quote
for odd things or one offs your best bet is to find someone local who can make them - to people with lathes this is one of the simplest things to do.
gazza285
posted on 23/4/07 at 10:12 PM Reply With Quote
Stainless has to be the most God-awful material to work with, its hard to start with, picks up for a laugh and work hardens for an encore. Added to that it distorts with heat (such as welding) to a huge degree, is shiny and doesn't go rusty. It does tarnish, depending on type, and is hard to maintain a uniform finish on.
7/16 is a bit small for an internal turned thread, use a tap. Get a good tap, not one of the carbon steel ones, and I would recommend that the internal diameter is bigger than the recommended tapping diameter. If you have to drill out the insert first then use lots of force with a slow drill speed, and use plenty of lubricant. If you are planning to weld the insert then I would recommend running the tap down carefully after the welding. Good luck.
stuart_g
posted on 23/4/07 at 10:50 PM Reply With Quote
Thanks for the replies. I know stainless is the most awful stuff to work with but that is what the cahssis is made of so I have to use it. The inserts are for top harness mounts and need to be welded through a chassis member and 7/16 is the harness bolt size so I want to use it.
907
posted on 23/4/07 at 11:51 PM Reply With Quote
Good news.... I have a lathe.
Bad news.... I don't have a tap.
If your can't get them anywhere I'm sure we could sort something out.
Just a thought. Is the 2B chassis 409 s/s?
If so, they would need welding with 309 or 312.
Paul G
stuart_g
posted on 24/4/07 at 08:00 AM Reply With Quote
Paul G
Paul,
Thanks for the offer. I have been contacted by someone who can make them for me now.
I've no idea what grade the chassis is made from, I could contact them to find out though.
Stu.
907
posted on 24/4/07 at 04:24 PM Reply With Quote
No problem Stu
Paul G
New Topic New Reply
