New Topic New Reply
Author: Subject: book mistakes, any chassis sections too short?
Cousin Cleotis
posted on 3/8/03 at 03:48 PM Reply With Quote
i have no where to store full lenghts of steel, so i will have to cut all the sections roughly to length then square off the ends after wards. i need toknow if any of the sections in the book are too short.
Thanks, Paul
Mark Allanson
posted on 3/8/03 at 09:25 PM Reply With Quote
I didn't use the book for the chassis, but I can confirm that J B McSorleys's plans are dead on - so no worries
Make sure you get the angles right on M1 & M2, I misread the plans and cut them to 50 instead of 40 degrees - my only problem
burgessj
posted on 3/8/03 at 10:13 PM Reply With Quote
So far I have found pieces C,Q,P,J1 and J2 to be wrong.
C, Q and P are too short in both Book and McSorley. J1 and J2 are too long in Book but correct in Mc Sorley.
See my earlier post (need help with plans) for further details..
Good luck and let me know if you want me to measure any bits on mine..
JohnB
stephen_gusterson
posted on 4/8/03 at 10:48 AM Reply With Quote
looking at your chassis -
I made my top and bottom 'planes' before putting in verticals, but perhaps thats a personal thing. That way you can build both 'planes' on the base board rather than building off the verticals which may introduce errors.
Have you put your engine rails in a tad too soon?
DONT cut your steel in one go. That way the little errors here and there will be apparent before you get to a situation where summat is 10mm too short.
atb
steve
[Edited on 4/8/03 by stephen_gusterson]
Mix
posted on 4/8/03 at 03:28 PM Reply With Quote
Use the book / Mcsorley as a guide, cut your steel to lenghth + a tolerance, (say 30mm). You will end up spending time cutting twice but you should save too much waste. At the end of the day though the cost of the chassis raw material is probably relatively cheap. I paid about £6 / 6m length of 25mm RHS.
Mick
New Topic New Reply
