New Topic New Reply
Author: Subject: Modifying to fit 4AGE motor
andrewturner
posted on 1/5/07 at 11:55 AM Reply With Quote
I want to get my motor further back in the chassis so the gear lever is in a better spot and for better weight distribution.
Can I cut away "Q" or modify it in some way to give myself more space.
Ivan
posted on 1/5/07 at 01:58 PM Reply With Quote
I've done it for my motor but you have to be carefull to replace the strength you've lost - I made a "bridge" of plates and tubes as per below.
Replacing Q
Replacing Q
The idea was to transfer the loads into the plated transmission tunnel box that I've added as per Cymtrix - also I have two R's to improve the chassis's torsional rigidity.
I certainly wouldn't do it without some compensation to replace the lost loadpath.
[Edited on 1/5/07 by Ivan]
andrewturner
posted on 1/5/07 at 05:27 PM Reply With Quote
Hi Ivan I see you are in Cape Town, I am in PMB I cant see what you have actually done can you send me some better pics
Ivan
posted on 1/5/07 at 07:50 PM Reply With Quote
Andrew - will draw it out in the next few days - find photos are never very clear - one of the potential problems of moving the engine back is making space for the bellhousing between the two H members in the transmission tunnel which is ony realy possible if you have a +4" chassis.
Basically what I did was remove Q between the H members the run new members back to the midpoint of P in a V shape then fill in the top with 1.2mm plate.
scudracer
posted on 6/5/07 at 10:47 AM Reply With Quote
I'm also planning to use a 4AGE & T50 trans in my Seven. Any ideas on where to to get dimension drawings for this engine & transmission? Would be a big help.
Shameless-ad-supported-blog-that-belongs-to-my-friend plug - http://www.sevenbuilder.com & http://www.bikervoodoo.com
New Topic New Reply
