The Baron
posted on 1/5/07 at 07:38 PM |
Steering Column Mounting
Just as I thought I was nearly there, I have to redo my steering column mounting as there was too much movement in the structure when you gave the
steering wheel a good tug.
I am struggling to come up with something neat. Does anybody have any photos of there steering column mounting they could share.
The one I made this evening consisted of a bit of box section across the car (behind the dash) with two box section uprights to bolt the column to,
but again was to flexible. I guess that it needs to attach between the side of the transmission tunnel and the top chassis rail.
SWHBO can sense the end is near and is not moaning (well, not too much) about me being out there in the evenings as well as the weekend. Bless
her!!!
The Baron
big_wasa
posted on 1/5/07 at 07:56 PM |
Mine
mark chandler
posted on 1/5/07 at 08:12 PM |
My effort, welded some nuts into the tube and a washer further down, just bolts in.
I welded diagonals from the middle to the edge of the rear of the scuttle, it braces on this.
[Edited on 1/5/07 by mark chandler]
caber
posted on 1/5/07 at 08:27 PM |
Mine is pretty robust, a 5mm plate supported by 1" tube off the side rail the tunnel and a third to the bulkhead rail. you can see if you look
at the on its wheels photos in my archive. It is set up to allow the adjustable column to adjust!
Caber
flak monkey
posted on 1/5/07 at 08:31 PM |
Heres the GTS method.
Theres a tube run across inside the scuttle, and then two 3mm plates bent at 90deg to bolt the column to.
[Edited on 1/5/07 by flak monkey]
Sera
http://www.motosera.com
omega 24 v6
posted on 1/5/07 at 09:22 PM |
My effort
Upper column mount
But it may still need tied back to the firewall.
RazMan
posted on 1/5/07 at 09:33 PM |
Mine is a bit of lateral thinking (and using what I had lying around) I couldn't think of any other way to allow an adjustable column to move up
and down and a stainless door hinge seemed a logical choice.
Raz
DavidM
posted on 1/5/07 at 10:57 PM |
And mine:
The Baron
posted on 2/5/07 at 05:49 PM |
Cheers chaps!!!
I've now cracked it!!!!!!
Many Thanks for helping me shift my mental block!!!!!
The Baron
