VinceGledhill
| posted on 4/8/03 at 10:40 PM |
G1 and G2 Distances for 2.0 Pinto
The book says that G1 and G2 can be moved to accommodate the engine fitment. However, I'm going to build my chassis first and get a donor
later. Does someone have the measurements from their car fitted with this engine? I don't want to weld it up, then grind it off and do it
again later.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
James
| posted on 5/8/03 at 11:09 AM |
again later.
Hi Vince,
To be honest it depends atleast partially on where and how you decide you want to do your engine mounts.
Just bear in mind that the starter motor gets in the way if you put them too close together.
I can measure mine tonight if you like.
James
Mark Allanson
| posted on 5/8/03 at 12:33 PM |
Vince,
I did exactly what you are doing, but numbnuts didn't ask this question first. I welded the Gees as per book and the fitted the Pinto - and then
had to cut out a section. If you put the N/S G 1" outboard, you will be OK The picture shows it all.
I am sure you will be able to help me out soon, I am just about to embark on stripping out my loom
VinceGledhill
| posted on 5/8/03 at 04:54 PM |
Hi Guys. Thanks for that. So basically I will put G1 one inch towards the outside of the car.
No problem. Great this computer.
If you do have a problem with the wiring then please give me a shout on the mobile 07736 202101 I'll be only too happy to assist where I can.
Regards
Vince Gledhill
Jon Ison
| posted on 5/8/03 at 04:57 PM |
why not leave those two out till you have the doner engine, you may even change engine choice by then......
just a thought.
| posted on 5/8/03 at 05:15 PM |
I put mine far enough apart to drop the engine out downwards if necessary. If you are making your own engine mounts it's not too critical.
yours, Pete.
VinceGledhill
| posted on 6/8/03 at 12:00 AM |
Good thoughts guys. Making my own engine mounts. Yeah why not.
Steel arives tomorrow. Can't wait.
Regards
Vince Gledhill
jcduroc
| posted on 20/9/03 at 11:19 PM |
yours, Pete.
I've asked Mark Allanson about this in another thread but here it goes:
From the photo he posted in this thread it seems the starter motor is "the" problem especially with the engine mounts. But if these go,
let's say, at 45º to the sides instead of going to the lower tubes HOW CLOSE could you have the G tubes? Closer than the book they could come
directly from the tunnel to the apex of F-FU-E.
I guess theres's no answer.
[Edited on 23/9/03 by jcduroc]
JCM
