New Topic New Reply
Author: Subject: Front wishbones vertical alignment
minidoido
posted on 14/5/07 at 04:43 PM Reply With Quote
Hi!
I searched the forum and found nothing regarding this matter:
How do I align the top and bottom front wishbone?
I found this picture somewhere. Is this ok?
Thank you for the help.
[Edited on 14/5/07 by minidoido]
James
posted on 14/5/07 at 05:14 PM Reply With Quote
Here's the jig I used...
http://www.locostbuilders.co.uk/photos.php?action=gal&user=James&folder=Bracket%20Jig
I got the 22mm (25mm with wide track wishbones) with a plumb line through the top wishbone threaded part.
HTH,
James
kb58
posted on 14/5/07 at 05:24 PM Reply With Quote
What do you mean by "how do you align them?" Do you mean physically or conceptually? If you mean physically, it means screwing one rod-end further in, and backing the other one out. The goal is to move the outside end of the A-arm toward the front or back of the car. For proper caster, you want the upper A-arm to be toward the back of the car and the lower one toward the front. The 5deg listed is okay, but a little on the low side.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Mark Allanson
posted on 14/5/07 at 08:09 PM Reply With Quote
If you want to use symetrical suspension pickups, this drawing may help Rescued attachment Wisbone Modification.JPG
minidoido
posted on 15/5/07 at 07:51 AM Reply With Quote
Thank you for your help!
New Topic New Reply
