Author: Subject: how to controll IAC valve on Pinto
joscorstjens
posted on 20/5/07 at 10:44 PM Reply With Quote
Hi, I'm trying to figure out how the IAC valve on the Pinto is controlled. Is it reset at every startup? Is the valve driven by a stepping motor or just pulse width controlled? Does anybody have more info on the electric part of the IAC?
tia
jollygreengiant
posted on 21/5/07 at 02:25 AM Reply With Quote
Just a solenoid opened by a pulse and closed by switching off current/voltage flow. Switched off possition is closed so automatic reset if you want to call it this.
