dyntan
posted on 22/5/07 at 12:40 PM |
engine clearance
i'm setting up to fab my engine mounts. i've set the engine as per book at 1 inch below the chassis, the problem is that at this height
the rocker cover and especially the oil filler cap fouls the bonnet. how low can i safely go for normal road use would 2 inches be too much. the
engine is a 711m crossflow. any ideas appreciated
Phil.J
posted on 22/5/07 at 12:51 PM |
Personally, I would shorten the sump and pick-up everytime in order to get the engine as low as possible. adding a wing on the sump to get the
capacity back.
Getting that bloody great weight as low down in the chassis as possible will pay dividends in handling, plus I've not seen a car yet that
doesn't look better without a bonnet bulge or opening.
posted on 22/5/07 at 12:53 PM |
2 inches between sump and concrete? No way (not if you're going anywhere near speed bumps anyway)!!!
3" for me is the bare minimum, 4" if possible....
To an extent it depends where fore/aft the lowest point is. If its directly between the front wheels its less of a problem that if its half way
between the front / rear wheels.....
kb58
posted on 22/5/07 at 01:30 PM |
I think he mean lowering the engine 2", not 2" ground clearance. About the low engine being okay if it's between the front wheels,
I have to disagree. It's all fine as long as all you hit are speedbumps - while traveling at walking speed. Yes, in that case the engine will
rise with the tires, lifting the engine over the bump.
Someday, though, the car will cross this same speedbump at speed, for whatever reason. Now, the suspension will deflect, absorbing the height of the
speedbump, while the engine/chassis won't move relative to the ground. That's when there's going to be a real problem!
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
DavidM
posted on 22/5/07 at 01:42 PM |
My 1300 crossflow has a standard sump which is 1 3/4" (45mm) below the chassis. I moved the oil filler to the back of the rocker cover, but
otherwise it all fits under the bonnet except for the air filter. That will go as well soon.
I've set the ride height on mine to the dimensions that Westfield use and my sump has never hit anything, including those bumps that your wheels
go either side of.
Can't remember ride height dimensions off hand, but I'll have a look tonight.
Edited to say, if it's a 1600 xflow it's about 1" higher than the 1300., but would still fit under the bonnet in mine. My nose cone
is 8" high from the top of the chassis.
[Edited on 22/5/07 by DavidM]
phil m
posted on 22/5/07 at 03:16 PM |
I think luego bodywork is taller which may help accomodate this
My sump is only just 3 inches of the ground and apart from the odd spped hump it's ok
Phil
phil m
posted on 22/5/07 at 03:23 PM |
Bigger !!!!!!!!!!!!!!!!!!!!
graememk
posted on 22/5/07 at 03:45 PM |
god mines lower than that lol
but i have a spare sump lol
dyntan
posted on 22/5/07 at 08:16 PM |
thanks for your comments
gonna set it at 1.5inches below the chassis and move the oil filler i think
