bpgoa
| posted on 23/5/07 at 03:54 PM |
Roll Bar height
how high does the roll bar behind your head come up from the top of the rear suspension mount plates....
I've found a tube bender who's half the price of a roll bar... but i got to give him a drawing..
On and On the River flows... We the Undertow
worX
| posted on 23/5/07 at 03:58 PM |
It appears that the manufacturers don't all do it a regulated height.
The pinnacle of this difference shown mostly in the fact that MNR measure people for their roll bars so that they are specifically safe.
Take Agriv8's roll bar for instance - some say it seems a tad high, but he know it was made to measure and therefore most safe.
I am happy to measure mine for you, and as we are (IIRC) roughly about the same height I would think you would be able to gauge whether this was
suitable for you or not!
cheers,
  Oulton small
[Edited on 23/5/07 by worX]
kb58
| posted on 23/5/07 at 04:04 PM |
Think of it this way. Imagine being belted into your car, and having the car suspended 3 meters above the ground - upside down. Now let the car drop
with you in it. Will your head hit the ground? If the answer's yes, the bar's too low.
For starters, draw a line from the front nosecone to the top of your helmet. Now extend this line back further until it crosses where your roll-bar
will go. That's the minimum height. You will need it taller than this to account for the nose getting crunched down, and for you rising
up out of the seat in a rolling accident.
[Edited on 5/23/07 by kb58]
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
bpgoa
| posted on 23/5/07 at 04:05 PM |
You're a gent...
Thanks....
Agriv8
| posted on 23/5/07 at 04:09 PM |
cheers,
Thank you sir you put that in the most polite way possible.
Most people just laugh and go 'that looks stupid' ( I hope they are pointing to the roll bar and not me ) but I am happy in the
knowledge that my head is out of the way ( taking into account the contact points ( roll bar / engine ) if it does go over.
ps thats me in my MNR with the Supper lanky Size roll hoop.
yust a point while I am posting - I am sure you realise that you get what you pay for - what material is he making it out of ?
Kind Regards
Agriv8
bpgoa
Nice.... happy thoughts...
bpgoa
| posted on 23/5/07 at 04:12 PM |
75mm x 2mm CDS... main hoop..
50mm x2mm CDS diag / back struts/ front strut
Kind Regards
Agriv8
worX
| posted on 23/5/07 at 04:20 PM |
LOL
I had noticed!!!
and in your defense "most people" don't always know better!
the only difference I would of made in your case is the same "addition" that I had put into mine!
the forward diagonal:
  avatar
Kind Regards
Agriv8
Agriv8
Kind Regards
Agriv8
Sounds like you have found a good deal !!
regards
Agriv8
[Edited on 23/5/07 by Agriv8]
bpgoa
| posted on 23/5/07 at 04:21 PM |
Time will tell
worX
| posted on 23/5/07 at 04:24 PM |
does this mean you want me to measure it Adrian?
Thanks....
bpgoa
| posted on 23/5/07 at 04:25 PM |
Front diagonal
Steve,
after the trip around Stonleigh are in your car... i've decided to make that bar removable... just in case i get the opurtunity to scare the
sh!t out of the mother in law!!!
bpgoa
| posted on 23/5/07 at 04:27 PM |
Yes please...
you don't fancy measuring your prop shaft lenghts as well do you.... don't think i can mount my engine as far back as you have yours...
but wouldn't mind doing the comparison thing...
cheers
A..
worX
| posted on 23/5/07 at 04:31 PM |
My front diagonal is actually removable believe it or not - I wanted it that way for the same reason you do - but every person who's been in it
really likes it there!
Do you mean my prop or drive shafts? I take it since you mentioned engine position you mean Prop shaft?
If so this might be a bit tricky as I have a fully enclosed floor and don't really have a way to get to it for an accurate enough
measurement!
I will have a go though!
worX
| posted on 23/5/07 at 04:35 PM |
Roll Bar Height
It is 365mm to the bottom of the tube and 415mm to the top (which is a relief cos it's 50mm thick ).
I will try and measure the prop for you tomorrow...
bpgoa
| posted on 23/5/07 at 04:37 PM |
Mmmmm....
just looked on your website at the pics... going to copy the way the bars go together...
don't wory about the prop shaft measurements... sounds like a mision... will ask birich.. as he's mounted the same engine as i have...
bpgoa
| posted on 23/5/07 at 04:39 PM |
Thanks...
bpgoa
worX
| posted on 23/5/07 at 04:41 PM |
Don't copy them exactly!
I asked Mark (of MAC#1 several times   ) for the front diagonal to be placed closer to the drivers side so that when it actually run at
head height it was in the middle (or actually a tad closer to the pax) but they put it in the middle of the roll bar, SO , so that it runs really
close to the pax...
I also asked for it to be placed closer to the driver to make the most of the extra triangulation of the open cabin..................
bpgoa
| posted on 23/5/07 at 04:46 PM |
been as you've thought about this...
given that I realy am going to directly copy the height of the bar (because yours looks and is a sensible height for me - and i'm not allowed to
pick up leggy blondes) how far would you have had it offset from center towards the driver?
worX
| posted on 23/5/07 at 04:48 PM |
just rushing out!
will post a measurement on here after the 17.45 start spiderman3!!!!!!!!
bpgoa
| posted on 23/5/07 at 04:51 PM |
enjoy
RK
| posted on 23/5/07 at 06:21 PM |
While we are on the subject..
What do people think of a full cage with side protection, for the road? I don't want a minor accident to turn into a fatal one, especially if
I'm going to be involved.
| posted on 23/5/07 at 07:11 PM |
a full cage is an excellent idea tbh. I dont think upside down is going to be fun however good a plain rollbar is, far too much chance of catching a
bush in the face, or worse.
The weight penalty isnt as bad as it could be if you work the cage in well as it adds good strength.
kb58
| posted on 23/5/07 at 07:16 PM |
Just be aware that slamming your head into the side-bar isn't going to be much fun. In fact, if the car slides into a dirt embankement, the
side-bar might be what kills you instead of hitting the dirt. Some serious padding - if not a helmet - would be in order.
And its book -
