kendo
posted on 23/5/07 at 06:38 PM |
Headlamp Mount Help!
Hi
I'm looking for a measurement please.
How far out is the centre of the headlamp mount normally? For those which are welded onto the chassis Like MK etc.
flak monkey
posted on 23/5/07 at 06:40 PM |
You need to make it so that the outer edge of the lens is no more than 400mm from the outer most point of the car.
You can work it out from that.
Sera
http://www.motosera.com
stevec
posted on 23/5/07 at 06:42 PM |
On my Indy, the centre hole for the headlamp mount is 5 inches from the outside edge of the top chassis rail. Hope that helps.
Steve.
kendo
posted on 23/5/07 at 06:59 PM |
Bingo
Exactly what I was after.
nitram38
posted on 23/5/07 at 07:37 PM |
Remember that the 400mm is from the widest part of the car and that could be your rear wheel arches.
If you measure them too tight on the front cycle wings, you could find Mr sva failing you.
