nitram38
| posted on 5/6/07 at 12:44 PM |
Today's Project X progress
Today I made part of the rear subframe and fitted the front wishbone rod end adjusters.
The subframe is not completed yet and is only tacked. The manifold is only on loose too. You can also see the reverse starter motor hanging and the
chain diff. Neither are fixed and the sprocket needs to be changed.
Some names I came up with: The Quark, Isotope, Dark Matter. I can't seem to think of anything remotely similar to ATOM and still making it sound
cool !!
  rear subframe
[img][/img]
[img][/img]
[Edited on 5/6/2007 by nitram38]
Hammerhead
| posted on 5/6/07 at 12:57 PM |
looking good.
Names:
MOTA (atom backwards)
or R1 Mota etc
Reactor (as in nuclear) R1ACTOR
I'll have a think.
garage19
| posted on 5/6/07 at 01:08 PM |
Where did you get those rod end adjusters from?
DIY Si
| posted on 5/6/07 at 01:12 PM |
Looking good. When are you hoping for completion?
As for names, have a look at this page/site for some "proper"
physics names.
Lepton and muon aren't bad ones. The experimental physics bit has some weird names in it too!
Sun Tzu, The Art of War
iank
| posted on 5/6/07 at 01:17 PM |
Gotta be "Tachyon"
The word tachyon derives from the Greek (tachus), meaning "speedy."
Anonymous
nitram38
| posted on 5/6/07 at 01:22 PM |
I Designed them in solidworks and got an engineer to make them.
Basically they have an internal thread inside a steel cup.
Release the locknut and use a small bar to turn the adjuster. Afterwards close the nut and use lockwire on the adjuster.
I had the adjuster zinc plated and I also had to ream the cup out after welding.
robertst
| posted on 5/6/07 at 01:44 PM |
the name ATOM is cool because it is given to a very cool car.
imagine how uncool it would be in a Kia or a Daewoo...
"isotope" is kinda querky for a car
what about Zenith? i kinda like that name. although a bit tacky because of its meaning and stuff.. but sounds cool
Tom
AdamR
| posted on 5/6/07 at 02:15 PM |
quote: Originally posted by nitram38
I can't seem to think of anything remotely similar to ATOM and still making it sound cool !!
Proton?
TGR-ECOSSE
| posted on 5/6/07 at 02:28 PM |
You could call it a phastasfeck
zxrlocost
| posted on 5/6/07 at 03:15 PM |
or "atomic bomb" yeah!
nitram38
| posted on 5/6/07 at 04:01 PM |
Mimic?
Dillinger1977
| posted on 5/6/07 at 04:08 PM |
damn I wish i had the nouse to just start something from scratch. Maybe next time i'll learn to weld and have a go
-Rog
russbost
| posted on 5/6/07 at 04:15 PM |
Martin
How about calling it the "Neutrino", I believe it's one of the lightest & fastest particles known IIRC
nitram38
| posted on 5/6/07 at 04:24 PM |
I thought of Neutrino especially if it is spelt NeutR1no
robertst
| posted on 5/6/07 at 10:38 PM |
quote: Originally posted by russbost
Martin
CALL IT "ENRICO FERMI!!!"
it kinda mingles with Pagani, Enzo, Ettore.
Enrico fermi... actually pretty cool name... might use that if i ever start up a car brand...
Tom
