bpgoa
posted on 12/6/07 at 01:07 PM |
Help with cut out in chassis
I've just fitted my zx10r engine into a book chassis.. but I had to cut through one of the lower chassis rails... there are two which run
parallel creating triangulation at the bottom of the engine bay.. i've had to cut a chunk out of the passenger side bar...
question is.. will this make a big difference... should i add in extra tubes to compensate and where.... i don't want to add steel in for
the hell of it... it has to work for a living...
On and On the River flows... We the Undertow
nib1980
| posted on 12/6/07 at 01:10 PM |
got any pics to help?
| posted on 12/6/07 at 01:21 PM |
when i fitted a zx9 into a book chassis, i think i managed to leave both bars in with the sump between them. Is the zx10 sump bigger or have you not
managed to centralise it?
Taz Surfleet
| posted on 12/6/07 at 04:21 PM |
Dont forget that a bike engine doesnt go in parallel to the diff looking at your pic I would have thought you should be able to get it in without
cutting the chassis.
mistergrumpy
| posted on 12/6/07 at 05:02 PM |
I've had to put two diagonals in to get past this lower rail with the sump.
[Edited on 12/6/07 by mistergrumpy]
mark chandler
| posted on 12/6/07 at 07:47 PM |
I added tubes in mine, they do not weigh much but must make a huge difference in strength
bpgoa
| posted on 13/6/07 at 12:47 PM |
pics... i hope
bpgoa
and another
| posted on 13/6/07 at 01:03 PM |
bit late now its in, but i would've had that engine 3" further over towards the driver, so that the prop cleared the tunnel by about half
an inch at the entry. Also, would not have the engine at that angle, IMHO it should be parallel to the centerline of the car.
ps you a levellers fan?!
[Edited on 13/6/07 by JoelP]
bpgoa
| posted on 13/6/07 at 03:06 PM |
no not a levellers fan... why did you ask...?
I talked to the guy's at MK and they said to set it like that... line up the sprocket face perpendicular to the propshaft bearing.. exhaust
50mmm off the top chassis line... sump 40 - 75 mm under the lower rails.. I'm going to try and get that chopped... sump line parallel to the
chassis rails.
anyhow... what about these chopped rails..
| posted on 13/6/07 at 03:31 PM |
from your sig:
is a line from a levellers song.
Anyway, just link the broken points to the nearest most suitable other points. This is my take anyway:
| posted on 13/6/07 at 03:35 PM |
god damn bitmaps...
bpgoa
| posted on 13/6/07 at 04:54 PM |
Levellers song!!!!
this was a strap line for one of Londons top Acid/hard Trance nights... what was the song??
diagram makes sense...
| posted on 13/6/07 at 06:38 PM |
this song!
http://www.youtube.com/watch?v=HyXN8G--MPM
bigrich
| posted on 14/6/07 at 10:52 PM |
this is the solution used on my chassis.
Rich
bpgoa
posted on 14/6/07 at 11:30 PM |
Now you show me...
after weeks of begging for help...
bigrich
| posted on 15/6/07 at 09:23 PM |
good things are always worth the wait
Rich
