Minicooper
posted on 12/6/07 at 04:24 PM |
Build Jig
Hello,
I'm going to get some 3/4 or 1 inch ply to make a build jig to layout my floor of my car on, what have people used to keep the tubes in the
correct position
big_wasa
posted on 12/6/07 at 04:41 PM |
little screw blocks from any diy place
B and Q ect Around a quid for 20
[Edited on 12/6/07 by big_wasa]
ecosse
posted on 12/6/07 at 04:50 PM |
Same as ^^^^^ plus I made up strips of flat bar with holes at either end, placed them over all the main tubes and screwed them into the base board.
Alex
Michael
posted on 12/6/07 at 06:09 PM |
Mines the same but my blocks where made of 25mm square x 50mm lengh wooden blocks.
Minicooper
posted on 12/6/07 at 06:48 PM |
Thanks Guys,
Went to B&Q got the blocks, pick up the wood tomorrow morning as I wasn't sure on the measurements I needed
posted on 12/6/07 at 07:00 PM |
how sturdy have people found different ply thicknesses to be? If you have it on tressles how much support does it need to have less than a mm flex?
sorry for the hijack!
andylancaster3000
posted on 12/6/07 at 07:22 PM |
I think ply any thickness will need to be properly braced to get it anywhere rigid enough. We built ours from some 8x2, 18mm(i think) ply top and put
on it a set of tressles. It has worked very well, being very stiff and we almost completely built the car up on it so you can work at a decent height.
Only recently has the car car been put onto the floor.
Photo in archive under chassis table!
Also a pic on our take on the jig under 'lower rails'
HTH
[Edited on 12/6/07 by andylancaster3000]
posted on 12/6/07 at 07:47 PM |
good god that looks solid!
i was thinking of getting 6 800mm wide kitchen base units, 3 on each side back to back, with a 1.2x2.4m board on top. This only supports it every
800mm though, so i then though that i could put notches into the top and put a metal frame under the ply. Easy to get it level due to the adjustable
legs, plus lots of storage underneath!
