joolsmi16
posted on 1/8/07 at 06:37 PM |
sierra/cortina upright
Is there any different in track width between the cortina and sierra uprights?
If I have cortina front end setup and replaced with the sierra upright with the track be the same??
Also can the escort steering rack fit the sierra upright.
designer
posted on 1/8/07 at 07:29 PM |
You cannot use the Sierra upright with the Cortina suspension.
joolsmi16
posted on 1/8/07 at 07:49 PM |
sierra uprights
Having looked at the suspension brackets layout for both uprights I can't see any issues in using one or the other.
The bottom wishbone is angled to 8 degrees on the sierra and not on the cortina when using the maxi joint, just wondering if the sierra is wider or
narrower in its track??
caber
posted on 1/8/07 at 08:36 PM |
KPI would be different. Cortina uprights weigh less than sierra. They can be got and if you are worrying about the cost you will end up spending a lot
more later that you weren't expecting to! I have just placed an order with Raldes for over £110 for stuff I didn't think about let alone
knew I would have to pay for One expense is a new speedo as I cannot route the mechanical speedo cable between the box and the dial ! i didn't
realise the problem until just about everything else on the dash was done
Little bits are the real killer on a locost budget!
Caber
Blakey_boy
posted on 2/8/07 at 11:57 AM |
If you use the Haynes version of the book for the Sierra and the original book for the Cortina FS then I think you will find your answer.
Track for the front is about the same but, you cannot mix designs
Gene Hunt:- If anything happens to that car, I'm coming round your house and stomping on your toys, Understand?
