New Topic New Reply
Author: Subject: Pre bent 1" square tubing
donut
posted on 7/8/07 at 10:53 AM Reply With Quote
The rear end of my chassis has right angle corners and not rounded ones like everyone else. Is there a place that will do pre bent 90 digree corner peices so i can cut off the corners and weld in the new ones?
posted on 7/8/07 at 10:57 AM Reply With Quote
Cut them off and put a bent strip of 25x3mm in instead.
donut
posted on 7/8/07 at 11:15 AM Reply With Quote
hmmmm, thats an idea
James
posted on 7/8/07 at 11:27 AM Reply With Quote
Maybe use some bent round tube so you get a nice radius when you tap the rear sheet around the corner?
It's not structural so it doesn't matter what the tube is from. Cut it off an old school chair if necessary!
I used some old gas pipe and bent it round the vice with a big hammer!
James
Guinness
posted on 7/8/07 at 11:41 AM Reply With Quote
Shopping trolley?
Not that I'm suggesting one of Tesco's fleet would give up it's life for the cause, but you know, if you happened to come across one that had escaped.
Mike
donut
posted on 7/8/07 at 11:56 AM Reply With Quote
some good ideas there, cheers
kb58
posted on 7/8/07 at 01:24 PM Reply With Quote
Funny you mention Tesco, as they just announced they're coming to the U.S. This should be interesting.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Confused but excited.
posted on 7/8/07 at 03:01 PM Reply With Quote
Certainly better than WalMart mate!
big_wasa
posted on 7/8/07 at 03:49 PM Reply With Quote
old bike handle bars are good for this.
Racer/ kids bikes tend to have some good 90 deg bends
posted on 7/8/07 at 05:30 PM Reply With Quote
They have almost completed anhiliating the competition in the UK, so I guess they have set their sights on bigger things now...
caber
posted on 8/8/07 at 10:00 PM Reply With Quote
I bought a couple of 90° weld bends for 1" steel pipe it is a bit thicker in the wall but is easy to get a flush weld to 1" thin wall tube.
Caber
New Topic New Reply
