New Topic New Reply
Author: Subject: Minimum Ride Height
posted on 30/8/07 at 12:54 PM Reply With Quote
Minimum Ride Height
Does SVA require a minimum ride height / clearance?
andyharding
posted on 30/8/07 at 01:21 PM Reply With Quote
Gotta be able to get it on the ramps!
procomp
posted on 30/8/07 at 01:36 PM Reply With Quote
Hi from a practical poit of view for road use after sva. 2"/50mm with extreme caution is as low as you would go.
cheers matt
nitram38
posted on 30/8/07 at 02:47 PM Reply With Quote
I wouldn't go any lower than 100mm. My car just scrapes speed bumps at this height.
My MotaLeira will have air suspension so that I can run at 75mm and raise to 150mm for speed bumps
posted on 30/8/07 at 02:56 PM Reply With Quote
100mm or 4" is generally accepted as a minimum height under the sump.
I have a Westfield manual that suggests 125mm / 5" under the front of the chassis, and 150mm / 6" under the rear. If you follow their instructions this puts about 100mm under the bellhousing, which is the lowest point after shortening the sump. As the Westie is (ahem) remarkably similar to the Locost then these figures are probably a safe bet...
procomp
posted on 30/8/07 at 05:57 PM Reply With Quote
Hi most track setup westfields with the sump stuck out the bottom can run as low as 3" without any issues just a bit of caution when needed.
Cheers matt
posted on 30/8/07 at 07:11 PM Reply With Quote
I should add that my dimensions were for road use, and avoidance of speed bumps!
New Topic New Reply
