New Topic New Reply
Author: Subject: Chassis Steel Quantity
delboy
posted on 2/9/07 at 05:44 PM Reply With Quote
Has anyone ever worked out how much of each section is required for a Chassis? I'm about to embark on building my own chassis based on the book with the IRS from the sierra ( the haynes roadster) and it would be helpfull if i knew how much of each to order from the stock holders. Additionally any advice for a beginer would be much appreciated.
ned
posted on 2/9/07 at 05:51 PM Reply With Quote
I believe mcsorley did a cutting list saying how much of each length required.
beware, I've got yellow skin
James
posted on 2/9/07 at 06:35 PM Reply With Quote
I was gonna say it's around 100m... but thinking about it, that seems a ridiculous amount!
HTH,
James
russbost
posted on 2/9/07 at 06:42 PM Reply With Quote
Just worked out the amounts for my chassis, which obviously isn't a 7, but nevertheless would expect quantities to be similar - around 45m.
speedyxjs
posted on 2/9/07 at 06:57 PM Reply With Quote
i am brought 47 meters and it looks about right
Omni
posted on 2/9/07 at 07:05 PM Reply With Quote
Here you go:
Haynes Roadster Website
Hope this Helps.
Omni
panichat
posted on 2/9/07 at 10:37 PM Reply With Quote
advice
Hi Delboy
The piece of advice which I wish someone had given me before I started on my chassis:
Even if you have done a welding class ... build something else using the same gauge steel before you start doing the chassis (an engine stand perhaps).
The standard of my welding has improved so much during the build - I really wish I had practiced a lot more using my welder and the 16swg steel first.
A related piece of advice that I was given (but didn't heed) was to spend as much money as I could afford getting good welding equipment at the start.
Good luck with your build - it is a lot of fun!
Dave
kb58
posted on 3/9/07 at 12:31 AM Reply With Quote
Originally posted by panichat
Hi Delboy
Dave
Those pieces of advice is in my book!
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
delboy
posted on 3/9/07 at 05:58 PM Reply With Quote
Thanks for the advice guys, fabrication is going to start this weekend. I've got a decent welder and am fairly proficient with it. I did previously race saloon stox and one of the main things you learn quickly is to weld properly when your life depends on it.
Mr Rob
posted on 8/9/07 at 06:09 PM Reply With Quote
Bit of usefull info
Digits used to represent thicknessess of plates confirm to standards called "Standard Wire Gauge".For Your ready reference some details are given below.
1) 8 swg = 4.06 mm
2) 10 swg = 3.25 mm
3) 12 swg = 2.64 mm
4) 14 swg = 2.03 mm
5) 16 swg = 1.63 mm
6) 18 swg = 1.22 mm
7) 20 swg = 0.914mm
8) 22 swg = 0.711mm
9) 24 swg = 0.558mm
10)26 swg = 0.46 mm
New Topic New Reply
