New Topic New Reply
Author: Subject: FEA program
novacaine
posted on 6/9/07 at 05:05 PM Reply With Quote
FEA program
as part of a 6th form project im in a team designing/building a Formula Vee race car,
are there any free/cheap easy to use FEA programs out there?
cheers
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
Ivan
posted on 6/9/07 at 05:08 PM Reply With Quote
Yes - Grape
twybrow
posted on 6/9/07 at 05:16 PM Reply With Quote
Student edition of ProEngineer is free, and comes with PRoMechanica.
iank
posted on 6/9/07 at 05:19 PM Reply With Quote
Is FAE a requirement for the project?
Unless you're experienced in their use a glue gun and a pile of balsa sticks will give as good results quicker.
Anonymous
Paul (Notts)
posted on 6/9/07 at 06:27 PM Reply With Quote
twybrow
where can I download a copy of the Student edition of ProEngineer for free as I am having trouble locating one...
Paul
balidey
posted on 6/9/07 at 07:56 PM Reply With Quote
Depends what you are analysing. Usually a free / cheap / easy to use one is not much use.
SolidWorks has an inbuilt one, which is OK for small, simple models.
But, unless you know what you are doing (and most people don't) you can get the wrong results. Now I don't mean the result is incorrect, I mean unless YOU, the person setting the restraints and applying loads and forces knows the correct way of setting it up you can get a very different result than someone else.
I don't mean to sound condescending, as I only have limited FEA experience, but i know several people with about the same experience as me who claim to 'know about FEA'. Its a very complex program to work properly, and you also need to undertand how to interpret the results correctly.
Another point is that FEA is not the answer, it should only be used to back up physical testing. A true FEA expert will tell you this.
But apart from that, if you have SolidWorks, then have a bash at CosmosExpress on a simple item. Its one of the easier ones I've seen.
dream
posted on 6/9/07 at 09:29 PM Reply With Quote
proengineer
I tried to learn solidworks but did not like it very much,this time i want to learn proengineer also,were can we get a free version off proengineer
twybrow
posted on 7/9/07 at 06:45 AM Reply With Quote
If you go to the ProE webiste PTC then I believe you can apply for one through that. You may need someone official from your school to do it on your behalf. They normally give you a CD which allows free use for a year.
twybrow
posted on 7/9/07 at 06:49 AM Reply With Quote
http://www.proeacademic.com/content.php?si=465
New Topic New Reply
