Ferg
posted on 13/10/07 at 05:59 PM |
Toe out mystery
I wonder if someone might do me a favour. The wheels on our Velocity XT toe out even when the rack, adapters and track rod ends are would tightly
together. I'm not sure the ride height is quite correct, but I think that may just make it worse. Can anyone measure the distance between their
track rod ends for me? Centre of nut to centre of nut.
jollygreengiant
posted on 13/10/07 at 06:03 PM |
You are using an Escort rack, not a Sierra one.?
Ferg
posted on 13/10/07 at 06:09 PM |
Er...
I assume so. It was Luego supplied. It's 1015mm long threaded end to threaded end.
keith2lp
posted on 13/10/07 at 06:33 PM |
Hi
You should have an Escort rack, I had to cut the adaptors down by about 10mm to get mine to toe in.
I think I removed 5mm from both ends of the adaptor.
Keith
Ferg
posted on 13/10/07 at 06:41 PM |
Ah.
I can understand taking some off the female end, but the other end threads into the trackrod end so how would that help? Did you have the lock-nut
between the trackrod end and the adaptor??? Or Loctite?????
