<<  1    2  >>
New Topic New Reply
Author: Subject: Welding pics 2
speedyxjs
posted on 30/12/07 at 10:02 AM Reply With Quote
Welding pics 2
Following on from this tread.
I spent a couple of hours yesterday doing more practice and breaking to make sure the weld doesnt break and playing around with the settings (turns out i had it on power setting 4 when i thought it was on power setting 5 ) and came up with this. (be as critical as you like. the last thing i want is to get to SVA and fail on my welding )
I think the wire feed may be a tad high
[Edited on 30-12-07 by speedyxjs]
bonzoronnie
posted on 30/12/07 at 10:09 AM Reply With Quote
If the power is set high, it looks as if you need less wire speed.
What material is that square tube. In particular the wall thickness.
Ronnie
RazMan
posted on 30/12/07 at 10:15 AM Reply With Quote
Yep, wire speed looks a tad too high, otherwise it looks plenty hot enough.
Raz
phelpsa
posted on 30/12/07 at 10:18 AM Reply With Quote
Looks pretty good to me!
You might want to turn to power up a bit and move the torch a bit faster as it gives a better looking weld Although If you're going to grind it down I would bother.
Danozeman
posted on 30/12/07 at 10:37 AM Reply With Quote
As said above looks good but you need less wire speed and maybe more power.
Dan
llionellis
posted on 30/12/07 at 11:09 AM Reply With Quote
You said, "be as critical as you like".
Well we all have to start somewhere but the chassis of a road going car is probably not the right place to begin. Skilled welders serve an recognised apprenticeship and train for several years before being let loose on any work of significance, even then their work is subject to non destructive testing. Looking at your weld I would suggest that it would fail any NDT. Initially it would fail on a visual inspection, if it had ultrasonics done it would probably show a lack of fusion at the root. If you were to grind the cap off then bend the weld along the line of the weld it again would probably fracture. I am sorry if I appear to be blunt but your life and other peoples lives could be at risk if any chassis welds fail. In the long term if "home grown " chassis fail either because of poor design or poor build methods then someone in authority will begin to look at our hobby and restrict our activities to sticking body kits to Corsas. Please get some instruction and help before fully welding your chassis.
Oh and a Happy new Year to you all
speedyxjs
posted on 30/12/07 at 11:15 AM Reply With Quote
Cheers for the replys guys.
Bonzo - its 1 x 1 inch 2mm thick rhs. i wanted to go a bit bigger because of the engine i am using.
andyharding
posted on 30/12/07 at 12:31 PM Reply With Quote
There is critical and there is rude and your post borders the two. Perhaps more positive suggestions on improvement and less "you are going to die" drama would be more helpful?
posted on 30/12/07 at 01:09 PM Reply With Quote
He may be bordering on rude (not my opinion) but he has a point ! Get some tuition, well worth the cost and will save you money/tears in the long run.
t.j.
Try to let the weld in front of the torch.
looks as if you did not travel at the same speed.
We all needed to learn (and still do), so don't be bothered by critics.
As you use 2 mm 25x25 the tube won't be the trouble.
I noticed that welding 25x25 2mm at 140A or 160A with 380 Volts for me is the best.
Lower results in a weld which is "on top" off the rails and not welded really tru.
What you can do is grind it so can see if the weld is melted tru. If so the weld is more than strong enough.
It is also not nessary to be a proffesional welder. I've seen bad welds on fabricated chassis and wishbones from different manufactures.
The chassis design is really on the safe side. So it won't crack down the first ride.
Regular checking like MOT does the rest.
So go on and try to find your way to a nice weld.
Happy building.
Mansfield
posted on 30/12/07 at 01:15 PM Reply With Quote
Dont be disheartened, welding can be an arse to get the hang off initially.
Things that helped my MIG learning were:
Not using a hand held helmet.
Using a 9EW lens
Stopping practicing on joints, straight runs up the box section means I wasn't spending most of my time cutting up test pieces. If I did a 6" run up the length of box I could vary my speed/torch angle etc to see whats best. 1" runs are not long enough for that.
Turn the wire speed down as far as it will go, slow the torch speed down to compensate.
Destruction testing is a good idea to see what you have produced. If you are welding joints, weld one side of the box and wring it backwards and forwards until it breaks off. This is what I did.
http://www.locostbuilders.co.uk/viewthread.php?tid=57862
Keep going but stop welding your chassis, you wont be happy with those welds once you do get the hang of it.
HTH
speedyxjs
posted on 30/12/07 at 01:22 PM Reply With Quote
I think im getting the hang of it now
Image deleted by owner
This one looks much better. All the practice i have done have gone through to the other side and the weld hasnt broken when i break it. I had lessons a couple of years ago but then went a year without welding and then obviously just tack welding while i was building the chassis. I have been trying the arc technique as in the website mangogroove posted on the original thread which i think is why they look so wide.
Mr Whippy
posted on 30/12/07 at 01:51 PM Reply With Quote
cool you getting it, not difficult really. Try resting you arm on something to stop any shaking. Oh and select macro on the camera to get close ups
[Edited on 30/12/07 by Mr Whippy]
speedyxjs
posted on 30/12/07 at 01:52 PM Reply With Quote
cool you getting it, not difficult really. Try resting you harm on something to stop any shaking. Oh and select macro on the camera to get close ups
Havnt got that option on my camera phone
Mr Whippy
posted on 30/12/07 at 01:54 PM Reply With Quote
ah, the phones...a bit of card behind the tube might get the camera to focus better, unless its fixed
posted on 30/12/07 at 01:59 PM Reply With Quote
dont know if someone has already said this but a good start is to have the power on full, unless you have a particularly big welder. But on 2mm section i would have had my 135 on full, adjust the wire speed to match. You do have to be careful to avoid blowing holes, but thats almost the idea - you know you have full penetration if it blows a large hole! But do this on scrap, not your chassis. Once familiar with full power you can wind it down if you want.
thunderace
posted on 30/12/07 at 02:27 PM Reply With Quote
sorry mate that looks very bad to me.
but i have been doing it for over 20 years .
turn the power up more then try it or grid the edges like this LIKE A V THEN WIELD IN IT TO FILL IT then try and brake it with a big hammer .
gregs
posted on 30/12/07 at 02:55 PM Reply With Quote
the best tip I was given when learning to weld was the pattern, ie lots of over lapping loops <5mm, rather than dragging the torch in a straight line. It gets more heat into the weld as you hold the weld pool in one place for more time.
Hope this helps. I'd strongly suggest you stop welding the chassis now until after pracitising on off cuts you are comfortable producing a good strong weld every time.
[Edited on 30/12/07 by gregs]
bonzoronnie
posted on 30/12/07 at 03:04 PM Reply With Quote
Critical. Not half !!??
I had a similar post on the Roadster forum.
This Kind of talk just makes my blood boil
The triangulation of this kind of chassis is where the strength lies. Not in the multitude of welded joints.
That said. A good standard of weld is still essential. You can never practice too much before welding the chassis tubes.
Any competent person should be capable of producing good welds with a MIG welder after a few hours of tuition.
To put it simply. The chassis constuction is not exactly " Rocket science" . If it were, we would'nt be allowed to build them.
OH, me.
Fulluy trained welder of 35 years. Have held ASME qualifications in Stick, TIG & MIG.
Instructor at my local Skill centre. Utill HM Goverment cut it's funding & closed it that is.
Background in the marine, structural steel & Power plant industrys just to list a few.
_________________________________
I thought that was RHS you were using.
You will need the current up a bit on that. If you have a smaller set, Probably full power.
.6mm wire will also help.
You will also need to grind a prep on the end of each tube to ensure full penetration.
Keep at it.
If you are not sure, just ask.
Dont let the words of one sceptic, put you off.
Ronnie
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
Building: Built haldane 100, retirement project Marcos GT
posted on 30/12/07 at 03:15 PM Reply With Quote
Agree with both gregs and thunderace here, file or grind a v shape groove, then when welding push torch foward, if you feel you're not getting enough weld pool into the groove then move tip side to side gently to fill the groove. this shouldn't be the case with 2mm though
but practice on scrap first, a jaguar engine will shove out a lot of power so i'd want everything to be as good as poss
you dont want to do all that hard work and then be disapointed if it fails
Good luck
posted on 30/12/07 at 03:34 PM Reply With Quote
I'd suggest making up lots of non structural bits first!!! Your welding is definately getting there (in fact, it's getting better than mine!!) but a poorly welded chassis will not be fun. Even ignoring the safety issue for a little while, if its not rigid, it'll handle like rubbish!!! Also, if you do find any failed joints once it's on the road it'll be a right PITA to re-weld them after its all painted, the bodywork is on etc.... Better to do it right in the first place...
I do acknowledge the issue re our gorgeous nanny state regulating the hell out of anything. I can quite easily see a situation where they say any amateur car builders have to have the welding assessed (rather like Part P for electrics)..... SVA is all well and good but when you compare it to the build-up assesment for amateur built planes it's pretty mild...
Unfortunately, most people start at the beginning(!) which means starting with the chassis welding- possibly the most structurally important part (or maybe that's suspension)....
Practice, practice, practice until your welds are 100% reliable and strong. Keep on posting pictures (welding porn )- the welding experts can give advice and the welding muppets (me included) can learn from your mistakes and learnings!!!
Mansfield
posted on 30/12/07 at 04:08 PM Reply With Quote
It could also be the case that your welder is poorly set up to start with. I am assuming you are using a Clarke 150 amp.
My Clarke 105EN likes a fairly tight feed roller and a loose as possible wire holder. Loose as in just tighter than unwinding itself.
You have already said you are using amps setting 5, which on a 150 amp welder should be enough. Have a play with the wire feed, you should be able to get a weld anywhere between 5 & 7, but you will have to radically alter your technique at these limits. There is a world of difference between 6 & 7 once you know what is going on.
There is a quote from someone on here, one of the more knowledgeable welders on here, that if you are blowing holes then you are just a fraction away from a proper weld.
Blow those holes buddy.
llionellis
posted on 30/12/07 at 04:16 PM Reply With Quote
Oh Dear!
Just got in, wished I had stayed out.
I am sorry if I caused any offense. I have seen some very poorly welded kit car components and chassis and I just feel that we should raise our game. I am not in a position to instruct any one about welding, I will leave that to the experts.
My blood boiling rude comments where meant to help not hinder.
Please accept my apologies for any offense I may have caused.
speedyxjs
posted on 30/12/07 at 04:56 PM Reply With Quote
Cheers guys. Been out doing more practice and got pretty good. Welds were much flatter and smoother and looking quite good. Then ran out of wire but i will get some more and go for .6 rather than the .8 i was using. Thanks alot for your help.
Edit - cutting a V in the workpeice, brilliant advice.
Mansfield
posted on 30/12/07 at 06:23 PM Reply With Quote
I found 0.6mm wire better suited to my slow style.
Seriously, try some 6" runs up a length of box - you will learn a lot more.
<<  1    2  >>
New Topic New Reply
