New Topic New Reply
Author: Subject: wall thickness flat oval wishbone tubing
Mave
posted on 22/1/08 at 12:41 PM Reply With Quote
What's the wall thickness of the flat oval tubing a lot of manufacturers use for their wishbones?
big_wasa
posted on 22/1/08 at 05:28 PM Reply With Quote
32mm x 16mm x 2mm wall
But I am buggered if I can find anyone that stocks it
paulf
posted on 22/1/08 at 08:51 PM Reply With Quote
Theres a steel supplier in Corby that i asked who could supply it in a range sizes but they had to order it in.I would go for 1.5mm wall thickness though.
Paul.
procomp
posted on 23/1/08 at 08:08 AM Reply With Quote
Hi it has been tried in 16g and did not work for long. Although that was a fairly wide track car. Nether had any problems with the 14g even with very wide track.
When trying to order ect don't ask for OVAL as that is true oval. Ask for flat sided oval furniture tubing. Most should carry this in stock in various sizes.
HTH cheers Matt
Mave
posted on 23/1/08 at 09:08 PM Reply With Quote
How much is 14 gauge in mm?
I know 16 gauge is something like 1.6 mm, but never understood the logic behind a higher number being a smaller dimension. Is it 2 mm?
iank
posted on 23/1/08 at 09:14 PM Reply With Quote
http://www.simetric.co.uk/sigauge.htm
14gauge is 2.03mm
Anonymous
Triton
posted on 23/1/08 at 10:50 PM Reply With Quote
AH Allen in Northampton stock it and call it flat oval...14swg is 2mm wall....like you say the higher the number the thinner the gauge....damn potty if you ask me!!!
Mark
Cousin Cleotis
posted on 29/1/08 at 07:01 AM Reply With Quote
Ralt Engineering, 32 x 16.7 x 2 CDS2 £7.05 per metre.
Paul
New Topic New Reply
