New Topic New Reply
Author: Subject: Roll bar
minidoido
posted on 23/1/08 at 05:33 PM Reply With Quote
Roll bar
Hi!
Its time for the roll bar. I don't now which one is better, but I think the first is the better looking!
I'm open to opinions...
roll bar
roll bar
Roll Bar
Roll Bar
roll bar
roll bar
onzarob
posted on 23/1/08 at 05:36 PM Reply With Quote
personally I like roll bars that RAC compliant...the rest just look weak...
[Edited on 23-1-2008 by onzarob]
Mr Whippy
posted on 23/1/08 at 05:43 PM Reply With Quote
bottom picture, none the rest are braced and would most likely either bend or just rip off leading to a very sore head
some of those cars look like tarts handbags oh and don't copy the top yellow cars filler caps that's dumb, if the car flips and the cap leaks (as many do) it will pour fuel all over the occupants heads.
[Edited on 23/1/08 by Mr Whippy]
indykid
posted on 23/1/08 at 05:45 PM Reply With Quote
Originally posted by onzarob
persaonlly I like roll bars that RAC compliant...the rest just look weak...
none of the above have proper backstays. they should run down to the back corners of the chassis and into a proper structural triangulated section. that or forward into the passenger footwell.
i personally really like my full cage.
tom
welderman
posted on 23/1/08 at 06:13 PM Reply With Quote
mines a double roll hoop thingy me bob. Stainless steel polished. Rescued attachment 2DSCF0051.JPG
Thank's, Joe
I don't stalk people
SeaBass
posted on 23/1/08 at 06:57 PM Reply With Quote
Originally posted by Mr Whippy don't copy the top yellow cars filler caps that's dumb, if the car flips and the cap leaks (as many do) it will pour fuel all over the occupants heads.
Uh oh - I think that's team Hellfire crossing you off the Christmas Card list....
Also I don't agree with your statement about caps leaking or your trigonometry - How will fuel pour "all over the occupants heads" (!) ?
[Edited on 23/1/08 by SeaBass]
minitici
posted on 23/1/08 at 07:11 PM Reply With Quote
You need one of these mate
Caged
Guinness
posted on 23/1/08 at 07:38 PM Reply With Quote
Seabass, I think he was referring to the other yellow car. I can imagine that you'd spill fuel even when filling up!
If I was doing this again, I'd be looking at a full cage. I was doing "70" on a blat the other day, looking out across the moors, and a 400ft drop off. You suddenly feel quite exposed up on the tops with just a decorative hoop!
Mike
SeaBass
posted on 23/1/08 at 08:01 PM Reply With Quote
Mwahahaha...
onzarob
posted on 23/1/08 at 10:31 PM Reply With Quote
It happens
procomp
posted on 24/1/08 at 08:49 AM Reply With Quote
Hi just remember that if you are ever thinking of doing anything with the MSA. Then it must comply with the blue books drawing in 45mm. Or if below 45mm then it must be fully msa/fia certificated regardless for use under msa regulations. And if over 2.0l then full cage is mandatory
HTH cheers Matt
New Topic New Reply
