New Topic New Reply
Author: Subject: Galvanising?
garage19
posted on 31/10/03 at 02:01 PM Reply With Quote
Galvanising?
Will be ordering an Indy chassis shortly and just wondering if galvanising would be an alternative to powder coating?
Have a friend who owns a fab shop and he is always sending big bits of fire escape and the likes off to be galvanised.
What d'ya reckon?
Alan B
posted on 31/10/03 at 02:17 PM Reply With Quote
General concensus says no.
Check for other posts on this, but I'm certain that was the overall opinion.
James
posted on 31/10/03 at 04:08 PM Reply With Quote
Pretty sure everyone said that the acid weakens the chassis (0.1mm off every exposed edge) and the heat treatment warps it! All in all not too helpful!
James
posted on 31/10/03 at 04:24 PM Reply With Quote
It's also a hot-dip process, so every tube has to have a hole in it to avoid bursting. These holes let water in, so it may make things worse!
The general opinion was to use a decent paint, and keep an eye on things once a year.
DJ
Bob C
posted on 1/11/03 at 05:37 PM Reply With Quote
zinc spraying???
How about zinc spraying as an alternative to galvanise? I don't know what the process involves but I did have a small subframe zinc sprayed once & no holes were drilled & it kept very clean under my car for at least 5 years.
posted on 1/11/03 at 11:23 PM Reply With Quote
.. but then the problem still exists when trying to secondary weld... though it is easier to remove than galvanising!
End of day - choice is your's!
New Topic New Reply
