Miks15
| posted on 15/3/08 at 10:04 PM |
IRS
Last couple of days ive started building up my chassis and made some good progress
the only bit im not too sure about doing is the rear end.
I m using the diff out of my bmw donor and am going to do a double wishbone set up but not sure how to do it.
So i was wondering if anyone had any plans/pictures of the set ups on the back of a standard chassis?
would be much appreciated as i will get to tht in a few days and wont b able to go further til i figure it out.
Thanks guys
chrisg
| posted on 15/3/08 at 10:21 PM |
The standard locost has a live axle, I belive there's a new book out that has IRS, and a forum with people building BMW based cars..
There might even be a link in my signature Cheers
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Miks15
| posted on 15/3/08 at 10:25 PM |
cheers chris, taking a look now
Miks15
| posted on 15/3/08 at 10:32 PM |
should the wishbones be of unequal length aswell btw?
ive seen this on most ive seen but it would be easier to do same length top and bottom?
and advantages to unequal length top and bottom?
nitram38
| posted on 15/3/08 at 11:02 PM |
Unequal wishbones and their mounting points will vastly affect the handling of your car.
As you corner the bones should lift on one side of the car and effectively lower on the other. In reality the body will roll and the tyre should stay
in contact with the road.
You need to work out first, how far your suspension will travel in a corner and then how much camber gain (normally negative on the lifting wheel and
positive on the lowering one) that you think will aid your car. My car gains about 0.25-0.5 degrees over it's working range.
I started with an end on 2D drawing of my wishbones in solidworks and I moved the upright up and down and measured the camber change.
You can also do this using cardboard templates and push pins for your pivot points.
[img][/img]
  up
  unequal wishbones
[Edited on 15/3/2008 by nitram38]
