GaryM
posted on 26/3/08 at 06:10 PM |
Converging 5 link trailing arm suspension design?
Does anyone know of any car that uses converging (when viewed from above) trailing arms in a 5 link configuration?
Gary
MikeR
posted on 26/3/08 at 06:26 PM |
what are you looking for?
Caterham link two arms together and they attach to the axle in the middle. This does away with the need for a panhard rod (making a 4 link design).
Simon
posted on 26/3/08 at 11:12 PM |
I'll have to check the Haynes book, but isn't the SD1 a 5 link set up?
Simon
procomp
posted on 27/3/08 at 07:56 AM |
Hi one of the Toyata's in the late 80's i think. Had simalar to your discription. I think it was the last of the RWD corolla's.
Cheers Matt
mcerd1
posted on 27/3/08 at 08:49 AM |
Scimitars ??
aerosam
posted on 27/3/08 at 01:15 PM |
Simon
The SD1 had a watts linkage, I'm not sure if that is the same thing.
mcerd1
posted on 27/3/08 at 05:11 PM |
the scimitars have a watt's linkage too, it just replaces the panhard rod
but i'd need to get the tape measure out to find out if the trailing arms are converging of not
[Edited on 27/3/08 by mcerd1]
TheGecko
posted on 27/3/08 at 11:36 PM |
In general terms, the whole point of having a 4-link location with one (or both) pairs converging (called a Satchell Link by the way) is to do away
with the need for a 5th link to do transverse location. Therefore a 5-link with converging trailing links would be unusual - not impossible, just
unusual. From memory a production car with Satchell link rear was the Holden Torana. The very first series Torana (late '60s) was basically a
rebadged Vauxhall Viva I believe but the later ones were pretty much Australian local designs.
More important question - why do you want to know?
Dominic
posted on 27/3/08 at 11:42 PM |
unusual.
I'm think a Satchell link used with a Panhard rod would bind. The axle would be forced to move sideways by the Panhard rod when in bump or
droop, but the Satchell link would resist this.
