Author: Subject: opb master cylinder warning switch
jamrogers
posted on 27/3/08 at 01:02 PM Reply With Quote
Has anyone fitted a balance bar and master cylinders from OPB? If so what did you do for a brake fluid level sensor - as far as i can tell their reservoir doesn't contain a float switch....
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
posted on 27/3/08 at 01:33 PM Reply With Quote
can't really see how you can detect fluid level without a sensor; maybe some sort of sensor in the pressure line?
jamrogers
posted on 27/3/08 at 01:50 PM Reply With Quote
no u need a float switch in the reservoir for the sva.... just wondered what other people used....
YouTube
Cubby
posted on 27/3/08 at 02:19 PM Reply With Quote
Check out the rally design site or Car builder solutions who do a separate switch .
soggy 3
posted on 27/3/08 at 11:26 PM Reply With Quote
I am using willwood mastercylinders and if i remember corectly i did a search and i found out mk 5 escort mastercylinder tops fitted, so i went down the scrappy, job sorted.
[Edited on 27/3/08 by soggy 3]
Oh and when your in the garage next put that tiger book in the bin.
Schrodinger
posted on 28/3/08 at 01:12 PM Reply With Quote
I used a Sierra cap on my master cylinder.
Keith
Aviemore
PeterW
posted on 5/4/08 at 04:25 PM Reply With Quote
One of these on ebay...?
260117638362 - Ford brake res cap
I've got Girling master cylinders and these fit perfectly
Pete
jamrogers
posted on 23/4/08 at 08:11 AM Reply With Quote
i got one from carbuildersolutions.co.uk fitted perfectly and had a test switch built in......
cheers everyone
YouTube
