SierraL_killer
| posted on 28/3/08 at 05:37 PM |
Chassis Paint - brush or spray
This is a sort of follow up post to an earlier chassis painting thread...
If I paint my chassis with a brush is it gonna look pants? Judging by the results I've had with hammerite I cant see it being a problem - I
just wondered if it was generally frowned upon by the world of Locosters?
I had intended on using Frost's paint as I've heard its pretty good stuff. Anyone else's thoughts would be greatly received.
Ta
carlknight1982
| posted on 28/3/08 at 05:39 PM |
ive used hammerite for mine and it looks great, you get alot of wastage with spraying and you have to be pretty good to avoid getting runs and stuff
like that
carlknight1982
like that
zilspeed
| posted on 28/3/08 at 05:56 PM |
I'm currently doing some bits of running gear with a can of Hammerite smooth which I had lying around. Seems a decent enough finish. These are
both post electrolysis.
Will be looking to brush paint or possibly spray the chassis with the same stuff.
  Hub finished
  Steering arm finished
caber
| posted on 28/3/08 at 06:05 PM |
Hammerite does not stick well to new metal, it will chip off. Using Hammerite red primer first is a much better idea then it sticks well brushed or
sprayed.
Caber
speedyxjs
| posted on 28/3/08 at 06:10 PM |
Im going to brush mine. I think spraying would be a waste of paint
chris_harris_
| posted on 28/3/08 at 06:47 PM |
Im using a truck enamel on mine, after spending hours taking hammerhit back off, due to it chipping very badly. Truck enamel or can be called chassis
black, is cheap goes on well brushed or sprayed, looks very good afterwards and is available from most auto paint suppliers. I use Jawel in
birmingham. I've only ever had good results with hammerite on rusty or sand blasted metal, when sprayed on.
Just my experiences for you to mill over!
Regards Chris
zilspeed
| posted on 28/3/08 at 07:42 PM |
As if by magic, good old Aldi may have something suitable next thursday.
Aldi metal paint
Four and a half quid a litre.
Tin of black and a tin of silver here I reckon.
RichardK
| posted on 28/3/08 at 07:46 PM |
I used rustoleum, sprayed but thinned out to 30% and am really happy with the result, yes there is a lot of wastage but I kind of impatient and
couldn't see me doing a good job brushing towards the end!!!
Paint Linky
Rich
Gallery updated 11/01/2011
iank
| posted on 28/3/08 at 07:49 PM |
Another option is a mini-roller. I've used POR-15 and a 1" brush on mine, and while not concourse it certainly doesn't look
pants.
Wouldn't use hammerite on a chassis personally as it seems to chip really easily.
Anonymous
SeaBass
| posted on 28/3/08 at 10:04 PM |
I know people will ridicule this but I'll say it anyway... A decent metal primer followed by Dulux Trade Gloss. It retains some
'flexibility' and doesn't chip off when you look at it like Hammerite.
JC
nitram38
| posted on 28/3/08 at 10:39 PM |
Because my chassis is always going to be exposed on the Motaleira, I have done a bit of research into paints.
Powder coating looks good......for a while, but is prone to flaking etc, hammerite is a strange paint when it comes to applying extra coats, it looks
good...................but chips easily. Powder coating is also a problem if you have to do any later welding alterations.
I have opted for Epoxy Mastic 121 which is supposed to bond to steel (two pack) and be able to withstand road salts and even battery acid.
Lots of magazines rate it.
I was going to spray it, but I found out that it can be brushed on as it smooths itself out.
At £108 for 5 litres (delivered) I don't want to risk wasting any by spraying it.
I am trying to get my chassis finished asap so that I can get it painted.
[Edited on 28/3/2008 by nitram38]
| posted on 28/3/08 at 10:49 PM |
I know I always say this but spray cans of
Plasticoat Red oxide primer
+ Plasticoat satin black
does it for me everytime. Cheap. B+Q stock 'em and it gives a cool powder-coat type finish...
Hammerite chips like a bustard.
RazMan
| posted on 29/3/08 at 10:04 AM |
I find that Smoothrite is more suited to rusted parts as it tends to 'grab' quite well to the rough surface. I used it with good results
on my uprights, driveshafts etc. My secret to achieving a good finish is to first brush on a heavy coat and when it is tacky to the touch, spray a top
coat on with the aerosol version - all the brushmarks dissappear and the end result looks quite like powder coating.
Raz
| posted on 2/4/08 at 08:38 PM |
Aldi metal paint
This stuff is superb, I've used it for no end of jobs and it's a tough finish. The silver is a slightly hammer effect not as lumpy as
Hammerite and brushes on well. Paint it thin to undercoat and put another coat on to finish it.
