New Topic New Reply
Author: Subject: Blast cleaning / Phosphating
jlparsons
posted on 31/3/08 at 01:41 PM Reply With Quote
Anyone know what thickness of steel is removed by phosphating (keyphos?) or blast cleaning?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
Mr Whippy
posted on 31/3/08 at 01:50 PM Reply With Quote
Cough! electrolysis..
what you cleaning?
aerosam
posted on 31/3/08 at 03:01 PM Reply With Quote
grit blasting will remove about 0.001-0.002" if your just using it to clean or remove paint. Using large grit and turning the blast pressure up will remove more.
If your just using a small spot blaster at home and not a large industrial machine then i wouldn't worry about it too much.
However if your are blasting anything thinner than 1mm I wouldn't reccomend blasting as it may deform your workpiece if your not careful.
Mr Whippy
posted on 31/3/08 at 03:32 PM Reply With Quote
best to mention that a lot of heat is generated on thin sheet from the friction of the beads and this can distort.
New Topic New Reply
