splitrivet
| posted on 17/11/03 at 10:49 AM |
Welder gone T*ts up
Hope someone out there can help,me welder, a Cerbora 185 has decided it dont want to play anymore cant seem to get any current from it on
anysetting,checked all the usual stuff,bad connections etc but it still aint having any.
Wonder if anyone else has had this problem.
Bob
| posted on 17/11/03 at 12:28 PM |
Bob,
Were you driving it hard when it went? Or did it just fail to work one day?
If it's the first, then the thermal overload may have cut in and not reset - or you may have burnt something out.
Otherwise, look for internal fuses (on my welder there's one tucked into the wire-spool bit - quite hard to find). It does sound like
you've lost power to the whole box (any lights showing? Fan running?).
A few places to start...
...good luck!
Mark Allanson
| posted on 17/11/03 at 09:11 PM |
The internal connection for the earth connector is usually a bit of aluminium strap on the lower end welders (sorry!). This can, over a period of
time, degrade due to constant heating and cooling and fail to carry the current. This will give symtons of low power, awful pentration, and the wire
breaking up before it gets to the workpiece so you end up with a small hedgehog instead of a weld. I replaced mine with a heavier piece of stainless
steel. You will also get over the other possible reason, the aluminium is bolted to the brass connector - enough said!
Hope this helps you out
splitrivet
| posted on 18/11/03 at 10:03 AM |
Hi guys, thanks for the input posted me question then got dragged out on a job and was out of the office all day.
Stripped the welder last night and found 3 diodes open circuit on the bridge rectifier a call to a local welder repair shop placed a new rectifier at
£58.
Hope this is help to anyone who gets the same fault.
Bob
