New Topic New Reply
Author: Subject: Move the engine or move the tube??
oldtimer
posted on 30/4/08 at 05:33 PM Reply With Quote
Having decided to use a Toyota 20v instead of the 16v I have a slight dilema. The water pump housing being in a different place means it now fouls the crossmember Q in 'the book'. This means either moving the motor and gearbox 50 cms foreward or keeping my mounts as is and cutting Q before positioning it 50 cms rearwards and adding some bracing. Moving the mounts is easier but makes the weight less central and my diff too short. Moving the tube has stress implications. Your thoughts/experiences would be appreciated.
Paul TigerB6
posted on 30/4/08 at 05:36 PM Reply With Quote
I take it thats 50mm and not 50cm!!
oldtimer
posted on 30/4/08 at 06:12 PM Reply With Quote
Ah yes - 50mm, my mistake
speedyxjs
posted on 30/4/08 at 06:30 PM Reply With Quote
I may be wrong but i would move the tube but make sure there is enough strength left and if nessercery add another
oldtimer
posted on 30/4/08 at 08:09 PM Reply With Quote
Move the tube and add some triangulation is my choise.
indykid
posted on 30/4/08 at 08:12 PM Reply With Quote
is it just the bit above the bell housing that needs moving?
an mk chassis doesn't have a J tube. if you want to maintain the strength in the chassis, move it back 50mm and gusset it either side of the longitudinal tubes or replace it with an x between the footwells.
an MK chassis is fine without it, but that doesn't mean it's right.
tom
oldtimer
posted on 30/4/08 at 08:23 PM Reply With Quote
Yes, just above the bellhousing - move the tube seems to be the answer. Regards.
oldtimer
posted on 3/5/08 at 10:24 AM Reply With Quote
Tube is out now so that ends the discussion! checked with a micrometer and there is no discernable flex without the tube but I'll fully brace it anyways. Thanks for all the advice. Makes swinging the engine+gearbox in and out a thousand times easier too!
Doug68
posted on 3/5/08 at 01:58 PM Reply With Quote
I'd ask the question on http://www.oz-clubbies.com the 20V Toyota motor is used a lot in Australia in se7en's.
Doug. 1TG
Sports Car Builders WA
New Topic New Reply
