speedyxjs
posted on 13/5/08 at 07:49 PM |
Bracket fabrication
Where can i get some wishbone brackets made up? Mine are larger than the book due to me using the Jag bones.
I would have like to make them myself but dont have the facilities to bent 3mm steel
indykid
posted on 13/5/08 at 07:53 PM |
MK engineering?
tom
posted on 13/5/08 at 07:56 PM |
If you're lucky you might find square section steel with the right size and 3mm wall thickness. Cut into appropriate lengths, then cut off the
side with the weld to leave a 'U' section.
I know people have done this with 2" square to give standard brackets...
Wadders
posted on 13/5/08 at 08:02 PM |
Or you could just use two angle brackets.
Al.
matt_gsxr
If you've got a vice and a blow-torch (standard plumbing thing) then making these isn't too bad.
I guess you haven't, in which case I apologise.
Matt
speedyxjs
posted on 13/5/08 at 08:09 PM |
Matt
I could get a blowtorch easy enought but our only metal vice is in my dads shed which is full of junk and i cant even get to it
NigeEss
posted on 13/5/08 at 09:01 PM |
How much wider ?
Will these do
Link to flea.
russbost
posted on 13/5/08 at 09:47 PM |
I do a wider bracket with a 10mm hole, could easily be drilled to 12mm if required, how big do they need to be & how many do you need?
