New Topic New Reply
Author: Subject: Chassis floor
mikeb
posted on 21/5/08 at 06:47 PM Reply With Quote
Chassis floor
I having a problem finding a supplier that will sell me one sheet of steel I need for my floor.
Metal Mania on ebay will sell me a cut to size sheet for the floor £31 for 1mm and £61 for 2mm. I'm not going to pay £61 but is 1mm thick enough?
Mike
PS if you live near Northants and have a bit lying around for £s let me know!
kb58
posted on 21/5/08 at 06:54 PM Reply With Quote
That's plenty, but it's very much a judgement call. Ask yourself how much protection against road debris you want? FWIW, I used ~0.5mm stainless!
[Edited on 5/21/08 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
big_wasa
posted on 21/5/08 at 07:01 PM Reply With Quote
I used 1.6 as per book.
If doing again I would use 1.2.
1mm should be fine
jacko
posted on 21/5/08 at 07:03 PM Reply With Quote
14g aluminium is what mk use on there cars that's what i have fitted with NO problems at all
MikeR
posted on 21/5/08 at 07:06 PM Reply With Quote
i used 1.2mm, by the time the car gets on the road it will be 1mm steel and .4mm rust, grinding dust and other assorted building rubbish
iank
posted on 21/5/08 at 07:13 PM Reply With Quote
1mm is thicker than the floor of your tintop so is plenty to prevent bits of brick/branch coming through (Caterham/Westfield use 1.2mm ally IIRC).
But without all the cunning pressed ribs it will be rather less rigid and may 'boing' as you get in/out.
Anonymous
chris_smith
posted on 21/5/08 at 08:14 PM Reply With Quote
where in the country are you? the reason i ask is i work for a multi metal supplier so may be able to get you something.
mikeb
posted on 21/5/08 at 09:57 PM Reply With Quote
northants unfortunately.
I've got good prices for ally but for the haynes they recommend a steel welded floor rather than a riveted ali one.
Triton
posted on 21/5/08 at 10:14 PM Reply With Quote
Better to rivet/bond ali sheet than risk welding thin steel sheet to your chassis...imho.
Mark
would this be the Mike who is about 200ft tall and lives near AZ?
www.tritonraceseats.com
www.hairyhedgehog.com
mikeb
posted on 21/5/08 at 11:23 PM Reply With Quote
200ft is a little over the top! 6ft 4 may be!
May be I'll go with ali, i found a good supplier!
New Topic New Reply
