Blue Fox
posted on 31/5/08 at 07:55 PM |
Welding floor in place
Welded my floor in today but just wanted to check how much weld I should be putting on - I've done approx 1 inch weld then 2 inch gap then 1
inch weld and so on, is this ok or should I "glue" some more?
jacko
posted on 31/5/08 at 08:08 PM |
More then enough if your welding is ok [ are you a good welder ]
Blue Fox
posted on 31/5/08 at 08:12 PM |
I'm not the worlds greatest welder but I'm ok. I work as an electrical engineer on dock machines so regularly work with full time welders
who have been doing it everyday for the last 20+ years and I'm not as good as them but for basic stuff I think I'm ok - I've been
jumping up and down on the floor today to make sure it was stuck!!
jacko
posted on 31/5/08 at 08:26 PM |
It will be ok then, mine is only fitted with pop rivets and tiger sealer it's alloy not steel
big_wasa
posted on 31/5/08 at 09:18 PM |
I didnt weld mine as I new I would go madf and warp it.
mines fitted with pop rivets and tiger sealer.
