New Topic New Reply
Author: Subject: Progress & what other brackets do I
big_wasa
posted on 7/6/08 at 12:13 PM Reply With Quote
Head lights are mounted
I want to get the chassis painted in the next week or so so....
Hard to tell from the pic but what other brackets do I need to add ? What have I missed that needs welding on.
Engine and rad fully mounted ect I am thinking of the little things.
Front brake flex hoses I was going to mount on the fiber glass side panels.
Is that good practice ?
cheers for looking.
worX
posted on 7/6/08 at 12:40 PM Reply With Quote
Re front brake flexi's - thats fine.
I think you've got it pretty much sorted.
Maybe you could add a couple of M6x25 bolts welded to the chassis in a couple of places (front end/under dash/back end) for earth points?
MikeR
posted on 7/6/08 at 12:47 PM Reply With Quote
earth points, hand brake mountings, harness mountings...
how are you mounting the battery, GRP nose / other panels?
Maradona
posted on 7/6/08 at 01:53 PM Reply With Quote
radiator mountings??
Diego,
The locost builder from Argentina
posted on 7/6/08 at 02:34 PM Reply With Quote
Tabs for the front brake flexis? (assuming that you're going to fix them to the chassis and not the bodywork).
RichardK
posted on 7/6/08 at 05:46 PM Reply With Quote
Bracket for the horn? How is the front number plate fixing? Just a couple of the ones I forgot
Rich
Gallery updated 11/01/2011
big_wasa
posted on 7/6/08 at 06:49 PM Reply With Quote
erm got me on the number plate ?
I hadnt thought that far ahead
could do with some ideas please...........
Rad / horn and "most" of the earth points done.
Ive not sussed how I am going to mount the nose yet hmmmmm
and still need to make a braket for the handbrake cables.
Just cut the nose out and made the grill
Triton
posted on 7/6/08 at 07:17 PM Reply With Quote
Cheeky wee bit of ali plate fixed under bottom of chassis then under nose?
www.tritonraceseats.com
www.hairyhedgehog.com
JohnN
posted on 7/6/08 at 07:45 PM Reply With Quote
If you are rear IRS, then same need for rear brake flexi fixing brackets.
Fuel pump
Chassis number (mine was stamped on a plate and welded to the chassis)
Seat mounting brackets?
locoR1
posted on 7/6/08 at 08:30 PM Reply With Quote
Looks like you've got it covered, Apart from your engine mounts You have made a realy big mistake
They should be BEC not CEC you know deep down its the way to go
Check out my CB500T Cafe Racer build diary
big_wasa
posted on 7/6/08 at 08:38 PM Reply With Quote
Dont ^^
there are only two reasons for not changing to bec.
First is lack of return on the zetec
second is ,it would take me another year to make the brakets
locoR1
posted on 7/6/08 at 08:46 PM Reply With Quote
Sounds like your nearly converted
I really need to take you for that blast I promised you! that should do the trick
big_wasa
posted on 7/6/08 at 08:52 PM Reply With Quote
It will make me poorer
locoR1
posted on 7/6/08 at 09:00 PM Reply With Quote
But HAPPY!!!!!!
t.j.
posted on 11/6/08 at 04:59 PM Reply With Quote
* looking for some popcorn *....
MEC Moped Engined Car
A car must have some mass to keep it nice on the road
New Topic New Reply
