larrythelathe
posted on 23/6/08 at 08:08 PM |
zx9r needles
any idea were i can find some?
its a c series carb.
Wadders
posted on 23/6/08 at 08:24 PM |
If you buy a dynojet kit, you get new needles with the kit.
Al.
]Originally posted by larrythelathe
larrythelathe
posted on 23/6/08 at 08:42 PM |
only need the needles
i have a kit fitted however i stripped down the carbs today and found one needle badley bent.
I didn't build em!!!!!!!!!
givemethebighammer
posted on 23/6/08 at 09:47 PM |
here maybe
http://www.allensperformance.co.uk/data-keihin%20jet%20needles.html
larrythelathe
posted on 24/6/08 at 07:45 AM |
NOPE
the ones i am after after are straight with no grooves
mackei23b
posted on 24/6/08 at 08:14 AM |
If they have no grooves, there not dynojet needles, sounds like stock ones to me.
larrythelathe
posted on 24/6/08 at 09:38 AM |
arr ha
Things are becoming clearer.
I have a receipt thats says cjk 001 tts kitcar jetting kit this would seem to be the main jets.
I am going to order some needles from TTS
what number grooves are you guys on for a starting point so i can drive it to the dyno?
mackei23b
posted on 24/6/08 at 10:52 AM |
I used the standard set up from Dynojet (4th groove from the top, you can get the set up from
http://www.dynojet.com/pdf/2185.pdf
Ian
