Micael
posted on 11/7/02 at 08:42 AM |
Steering colum
Im trying to fit the steering column in my MK chassie. On the metal sheet in front of the footwell there is a hole for the column bearing. On other
chassis the column goes just over the footwell. If I use this hole the agle of the steeringwheel will be more like a "lorry" type.
Does anyone else use this hole?
Some pictures of this can be found on
http://www.hugo.aman.as/bil.htm
//micael
bob
posted on 11/7/02 at 11:30 AM |
Micael
I'm using a later adjustable column on my MK,i've set the column high and dropped it down on the adjuster.
This seems to get the steering wheel more vertical towards the driver.
Micael
posted on 12/7/02 at 07:25 AM |
That could solve my problem
Is it from a Sierra? From which year do they have adjustable column?
Micael
bob
posted on 12/7/02 at 07:37 AM |
Micael
Higher specification models like Ghia's and GLSi normally have it,i have seen one come off an 89 1.8L so they could have been an extra when new.
The wheel also moves in and out too,which is another bonus
Micael
posted on 12/7/02 at 07:43 AM |
Ok,
Thanks for the info.
Micael
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
theconrodkid
posted on 12/7/02 at 07:34 PM |
I got an adjustable collom if you want it
