Jesus-Ninja
posted on 18/8/08 at 09:56 AM |
Good weight for a chassis?
What should a bare welded chassis weigh?
Suspension geometry tool here >>> http://www.locostbuilders.co.uk/viewthread.php?tid=81376
posted on 18/8/08 at 10:38 AM |
Depends on the chassis... ???
Jesus-Ninja
posted on 18/8/08 at 10:46 AM |
OK, book chassis. Looking for a range - like x is typical for a book chassis, but y is ultralight. Gives me an idea of where my (non locost) chassis
will come in.
posted on 18/8/08 at 11:15 AM |
Someone mentioned recently on here that a book chasis weighed around 68kg (in a thread on the Apsid 7 clone who's composite chasis weighed a
claimed 75kg).
82 Locost
posted on 18/8/08 at 11:18 AM |
It's difficult to do a comparison. In 'the book' Ron holds one above his head, but it doesn't have suspension brackets, floor
etc.
A caged race chassis with a steel floor weighs a ton, well not quite but you get the idea.
Jesus-Ninja
posted on 18/8/08 at 11:26 AM |
etc.
Yeah, that's the kind of ball park I was looking for.
Basically, I have designs for my mid engined chassis, and I can work out how much the steel weights, per unit of length, so I should get a finger in
the air of the weight of the frame. If it weighs in at 400kgs bare, then there's somethign very wrong......
UncleFista
posted on 18/8/08 at 11:28 AM |
etc.
Unusually for Uncle Ron, all is not as it appears
The chassis Ron holds up in the book is an aluminium version [1] of the "book" chassis.
[1] The general consensus is that it's a "bad" idea...
Tony Bond / UncleFista
Jesus-Ninja
posted on 18/8/08 at 11:38 AM |
quote: Originally posted by UncleFistaThe general consensus is that it's a "bad" idea...
Building it out of aluminium (which we know), or holding steel chassis above your head?
martyn_16v
posted on 18/8/08 at 12:01 PM |
Holding it's the easy bit, getting it there (and back down) is likely to cause you pain
matt_gsxr
posted on 18/8/08 at 12:57 PM |
live axle striker is about 62kg
This page is quite useful for weights
rich_miles_striker_weights
Strikers are at the lighter end of the spectrum.
Matt
posted on 18/8/08 at 01:10 PM |
I defy any person of average strength to pick and hold above their head a steel Locost (book) chasis.
This chap might do it though...(old Magnus Ver Magnussen)
[Edited on 18/8/08 by nick205]
Jesus-Ninja
posted on 18/8/08 at 01:28 PM |
Yeah, but could he fit in it and drive away?
procomp
posted on 18/8/08 at 02:16 PM |
Hi the chassis that good old ron holds above his head is the Aluminum chassis that MK thought they were going to produce.
As an example a Westfield live axle chassis complete with powder coating and suspension brackets BUT WITHOUT the rollcage weighs in at 45kg for an 18g
race spec item . And 56kg for a road spec 16g item.
The only extra to add to those figures to gain a comparison to a book chassis is the extra rear top rail and two rear uprights to the top rail.
And a full race spec rollcage should way no more than 24kg.
Cheers Matt
Michael
posted on 18/8/08 at 08:27 PM |
Takes two to lift my chassis, with some puffing, as it can be an awkward bit to hold (depend who gets the rad mounts stabbing them.
Then again i have manouvered (on skate wheels, whilst on its side (quite easily) and wheeled it about like a barrow, when rear axle is in situ and
manouvering to garage to install engine and gearbox.
flak monkey
posted on 18/8/08 at 08:30 PM |
GTS chassis was pretty light. Guess about 60kg.
I know I could manhandle it on my own fairly easily while i was riveting on the floor etc.
Sera
http://www.motosera.com
