tigris
posted on 31/12/03 at 10:55 AM |
Looking to braze stainless(exhaust) any tips?
Wrong forum, but I figured some of the pro-welders hang out here. I tried oxy-ace, but that seems very hard, so I guess I'll braze it what type
of rod can I use? probably flux coated. Any tips? Thanks
paulf
posted on 31/12/03 at 04:19 PM |
Flux coated nickel bronze rods would be best but any coated rod will do the job.Take into account that joints near the head may get veryhot during use
but i wouldnt epect them to be hot enough to melt a brazed joint unless you are using a turbo.
I made my exhaust from 16g stainless tube and welded it using 1.5mm stainless arc rods, i was doing it at home and planned on taking it to work to
finish with a tig but it worked out successful without .
Paul.
