New Topic New Reply
Author: Subject: orientation of ERW
Jesus-Ninja
posted on 5/9/08 at 12:12 PM Reply With Quote
orientation of ERW
Is there an accepted way to lay out ERW for the chassis? eg welded edge up (except for the verticles)
Or does it not matter, provided that what you do on the left, you do on the right?
chrisg
posted on 5/9/08 at 12:39 PM Reply With Quote
There's probably a sensible answer on the way, but do you think you need to get out more?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
posted on 5/9/08 at 12:56 PM Reply With Quote
When it's painted nobody will know which way up it is, left to right upside down or back to front doesn't matter.
Jesus-Ninja
posted on 5/9/08 at 01:00 PM Reply With Quote
Great - wasn't sure if, when loaded, the tube would favour (not sure that;s the right word) one side and deform unevenly.
I'm laying out my chassis bottom rail today for welding
JonBowden
posted on 5/9/08 at 02:07 PM Reply With Quote
I'm not an expert but...
If you imagine a a length of square tube being bent such that one side is in compression, the opposite side in compression and the other two at the sides. I would expect greatest strength when the welded side is either the compression or the tension side.
I hope that makes some sense.
Jon
kb58
posted on 5/9/08 at 03:02 PM Reply With Quote
I'd place the welded-side away from any drilling you're going to do because the weld is both really hard and thicker. If you're drilling rivet holes, it can make the drill drift and be too thick for the given rivet length.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Jesus-Ninja
posted on 5/9/08 at 03:18 PM Reply With Quote
Good tips - thanks
posted on 5/9/08 at 03:37 PM Reply With Quote
You'd have to be using marginal length rivets for the seam weld to make any difference, not the best practise.
kb58
posted on 5/9/08 at 04:12 PM Reply With Quote
I've measured 1.5mm seams that make the metal effectively twice as thick. The proper structural rivet size may very well call out different lengths for a material thickness change of 100%.
dnmalc
posted on 6/9/08 at 04:01 PM Reply With Quote
If you were bending the tube in the vertical plane and in isolation the best place to have the weld would be on vertical side as it would be close to the neutral axis (the point where there is no compressive or tensile stress). However in our cars the entire chassis is being bent and thus the top and bottom tubes tend to all be in compression or tension. In such cases it makes no difference so the advice should be to avoid placing the weld line near the stress raisers that are created by the holes in the tubes or at points where brackets brakets are attached.
New Topic New Reply
