thwang
posted on 6/9/08 at 07:08 PM |
chassis Recommendation for a pinto
hi all
newbie question
will the pinto fit straight in the standard book chassis or would it be better to build the 7+4 or the 7+442 or how low can you fit the engine i
think my old mk2 mexico sum was about 3 1/2" front the ground.
thanks inadvance simon
speedyxjs
posted on 6/9/08 at 07:15 PM |
Should fit ok but the mounts will have to be relocated
thwang
posted on 6/9/08 at 07:46 PM |
thanks speedyxjs
thwang
Mark Allanson
posted on 6/9/08 at 08:13 PM |
Loads of people have done it, a bit tight but not difficult, you will need a small alternator and a fabricated bracket. Chop the sump level with the
bellhousing, move the oil filler to the back of the rocker cover.
scutter
posted on 6/9/08 at 08:30 PM |
Why not try what i've done, which was to add an inch to the chassis height from the "H" tube at the rear of the dash forwards,
it's allowed a zetec to fit nicely
ATB Dan.
The Baron
posted on 7/9/08 at 08:12 AM |
I,ve got a standard chassis (original BYOSC for £250) with a pinto sat in it, the transmission tunnel will need to be different (wider) if you are
going to use the type 9 gearbox.
B
posted on 7/9/08 at 09:08 AM |
Put the engine bay reinforcing bar in the opposite side and it will fit easier in a book chassis.
thwang
posted on 7/9/08 at 10:57 AM |
thanks guys
chrisg
posted on 7/9/08 at 04:27 PM |
Haynes Roadster!
cheers
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
thwang
posted on 11/9/08 at 08:21 PM |
hi guys n gals
thanks for all the replys and thanks chrisg i,ve just ordered the haynes roadster manuels since its more for the sierra.
simon
chrisg
posted on 11/9/08 at 08:44 PM |
Thanks mate, I hope you enjoy it!
Chris
