posted on 23/9/08 at 01:51 PM | |
Square or Round Tube?
Assuming equal thicknesses, etc, which one (if either) offers the best structural strength?
mr henderson
posted on 23/9/08 at 01:54 PM | |
Round
John
Agriv8
posted on 23/9/08 at 01:58 PM | |
Oooo Thats the can of worms that is about to be opened.
But Round
and if it needs to be bent DEFINATLY Round.
'Second out Round 1'
Regards
Agriv8
l0rd
posted on 23/9/08 at 02:00 PM | |
Round
but cutting it properly and welding it i would think a nightmare
Ivan
posted on 23/9/08 at 02:09 PM | |
Your question is too open ended to answer directly - i.e. assuming the same wall thickness 1"square will be stronger and heavier than 1"
round but 1lb per foot round will be stronger than 1lb per froot square
[Edited on 23/9/08 by Ivan]
smart51
posted on 23/9/08 at 02:10 PM | |
round is better in torsion, square in bending, I believe.
Round, you have to cut fishmouths, which I found to be time consuming. Square, you somentimes have to cut compound mitres which is probably worse.
Round is a little harder to weld as you have to weld round the corner rather than 4 straight lines.
Round is lighter for the same overall size and thickness. That's why I chose round tube. I managed quite well with it.
posted on 23/9/08 at 03:17 PM | |
look around you; trees, the bones in your arms - nature favours the circle over the square.
for the same wall thickness and same weight (i.e. same cross-sectional area) round will be stronger.
i.e. 1 inch round with say 2 mm wall will be stronger than square of same c.a. and 2 mm wall - the sides of the square will be approx 0.787 in.
Depending on how you want to use the tube, in tenision/compression, wall thickness makes a difference.
For example a solid tube is easier to bend than a thin wall tubes of same c.a. think bicycle frames ... but here is a limit as you can have a very
large diameter tube with extremely thin walls - think cooking foil - that offers very little strength.
... there is loads more but I ain't best qualified so made generalisation.
In summary, you want strongest and lightest chassis, then round tube is the way to do it. (I think)
Alan B
posted on 23/9/08 at 04:04 PM | |
quote: Originally posted by l0rd
Round
Far from it.....and good fishmouthing tool and you are good to go...as said previously compound angles in square are a much bigger nightmare.
I've build built many of both type and often find a combo works well.
Syd Bridge
posted on 23/9/08 at 04:39 PM | |
This one's been done to death previously.
Any proper engineers out there, who would like to put numbers and algorithms to this?
Thus proving to the general masses that 1" square is stronger than 1" round, if equal wall thicknesses are assumed.
As put already, the square will be a little heavier, but will be stronger structurally, than round in every aspect.
Syd.
PS. Mr.Henderson, find some info on 'Moments of Inertia', before putting your other foot in that prodigious opening between your jaws!
Litemoth
Angle iron is great too. It makes a fantastic bedstead
MikeCapon
posted on 23/9/08 at 04:48 PM | |
This is interesting.
blakep82
posted on 23/9/08 at 07:04 PM | |
round.
though square is easier to work with...
________________________
posted on 23/9/08 at 08:33 PM | |
As always... ta!
Syd Bridge
posted on 24/9/08 at 08:42 AM | |
For those who took the time to look at that link above, and understand the numbers, it is VERY obvious that the square is the stronger tube in
every aspect, given same wall thicknesses and od's. AS I put previously!
Pleaase, no more uninformed opinions. There's enough BS on the i'net already!!!
Agriv8
posted on 24/9/08 at 09:31 AM | |
Syd as always you are 'probably statistically' correct But I would still want a round tube chassis over a square tube chassis and a round
roll bar protectin my noggin I would also prefer round wisbones over square ones.
TTFN
Agriv8
mr henderson
posted on 24/9/08 at 08:32 PM | |
And perhaps you could pull your nasty little head out of your nasty backside for 5 minutes . Typical keyboard warrior aren't you.
I don't know why I have become your latest target, I know you have a history on this forum going back years, upsetting people with your nasty
little comments.
Hissing Syd, you really are a nasty little piece of sh1t.
John
Syd Bridge
posted on 24/9/08 at 08:41 PM | |
Oh dear, it looks like handbags at dusk it is then! Come along you girls.....
Syd Bridge
posted on 24/9/08 at 08:45 PM | |
And as for keyboard warrior...I'm not the one posting all the trivia and one word posts, replying to anything and everything, just to get my
name in front of the world!
mr henderson
posted on 24/9/08 at 08:52 PM | |
You pathetic little nasty person. Even your screen name sounds nasty. Try googling "Syd Bridge" and see what comes up third result. Yes
the thread on this very forum from a few years back, featuring you!
John
Syd Bridge
posted on 24/9/08 at 09:14 PM | |
Gee, I'm famous. No.3 on a Google search!
All I have to do now is work out how to make some money off it, and I'll be made!!
Leave off the silly talk as well, it'll never achieve what you want. In the bush where I was brought up, people have thick skins.
Takes more than a few childish pathetic words, and that's all they are, just childish pathetic words, to upset me.
Syd.
Just had a look at that famous thread. I can see how you formed the opinion you have, Henderson. It appears that the scot who caused the damage
removed all his posts before exiting the forum. There is a LOT of posts missing that were in the original. CaLviNx or something similar was his forum
name.Shame really, when all's said and done.
[Edited on 24/9/08 by Syd Bridge]
Fozzie
posted on 24/9/08 at 09:45 PM | |
Thread closed......Fozzie (Admin)
