JimSpencer
posted on 30/9/08 at 08:11 PM |
Chassis Panels - Carbon Fibre?
Hi
Need to do a winter rebuild, the poor thing's getting very tatty, so it's time for a complete strip and sort out.
When thinking about re-doing the chassis panelling it's become apparent that good Ally isn't that much cheaper than Carbon Fibre..
As it's like painting the forth bridge keeping ally clean and you have to cover the insides of it with something to avoid the black marks on
clothes bit, I'm very inclinded to go for Carbon for the sides and rear, just keep ally for the floor (as it'll give a bit if bashed)
Any reasons why this is a daft idea anybody, have I overlooked something obvious?
blakep82
posted on 30/9/08 at 08:14 PM |
carbon ftw any day!
although, it is still very expensive... what about fibreglass?
________________________
Alan B
posted on 30/9/08 at 08:16 PM |
ftw?
blakep82
posted on 30/9/08 at 08:17 PM |
for the win
Paul TigerB6
posted on 30/9/08 at 08:18 PM |
Carbon effect ABS plastic???
skodaman
posted on 30/9/08 at 08:22 PM |
Plasterboard ftw (for the wallet lol). Yes it's not waterproof but no-one uses these cars in the rain anyway.
Skodaman
scoop
posted on 30/9/08 at 08:23 PM |
Your car looks great. How about just paint it all black? It would look pretty mean.
twybrow
posted on 30/9/08 at 08:24 PM |
Be aware that depending upon what resin/lacquer you use, the panels will probably change colour in the sun. Plus, it scratches easily (no more than
Alu, but more of an arse to polish back out). Also, you would need to make bespoke panels, as it won't bend/form like Alu will!
Richard Quinn
posted on 30/9/08 at 11:14 PM |
Rear panel would be a bit of a b*gger! Also, as mentioned above, very few expoxies are UV stable and will degrade/discolour over time.
Worth bearing in mind that carbon on it's own (no other cloth) is actually relatively fragile. Stone impacts etc could do quite a lot of damage.
procomp
posted on 1/10/08 at 06:59 AM |
Hi Jim.
Why not use 0.7 NS4 / 5251 grade aluminium. Then bond and rivet. This will strengthen the chassis considerably. For protection just paint it.
Price a 2m x 1M sheet should be no more than £25 Ea If brought in a small quantity Ie 2-3 sheets.
Cheers Matt
JimSpencer
posted on 1/10/08 at 07:58 AM |
Hi All
Thanks for the feedback, must admit had forgotten that carbon isn't UV stable..
Not keen on the plastic - though thanks for the suggestion, and as for not being used in the rain - you haven't been to an Anglesey sprint in
the summer then?
Matt - you have U2U as I must be contacting the wrong suppliers!
Thanks All!
